Building my motor...need help and suggestions
Old Sep 13, 2009 | 08:03 PM
STi k1LLa's Avatar
I currently own a 03 Evo 8. Has about 75k on the clock. Only mods are a boost controller and TBE. I have a AMS 35R kit on the way and have about 5g to play with on building my motor. Can someone send me in the right path as in how to spend this 5g wisely on makin my motor strong. Im new to the 4g63. Thanks
Old Sep 14, 2009 | 06:11 PM
VTEC Killer's Avatar
Building a 2.0 4G63 is textbook, with a built bottom end, bigger valves and cams, you can reliably make over 500whp with the proper engine mangement and fuel mods. you need to decide how much power you wanna make and what you want to do with the car to decide on the right engine parts.
If I built another motor, I would build a 4G64 block with the K1 crank or a MagnusMotorsports crank to make it a 2.2 liter motor. its a nice compromise because it will spool the turbo a little better and have more power under the curve, yet still have the ability to rev to 9,000 safely.
Old Sep 16, 2009 | 06:07 PM
Wheatley's Avatar
I went with the AMS 2.0 shortblock oliver TT/Ross combo. I then had my head checked and assembled the rest myself with all new oem componets. With the exception of ARP head studs.
Old Sep 16, 2009 | 06:43 PM
magyar86's Avatar
manley turbo tuff I beam rods, weisco pistons, manley 1mm oversized valves, supertech dual valve springs, ferra guides, P&P head
Old Sep 16, 2009 | 06:50 PM
Wheatley's Avatar
^After labor he would be way over 5k with all that head work.
Old Sep 16, 2009 | 06:57 PM
buchnerj's Avatar
^ +1 overshot the price range for sure
Old Sep 16, 2009 | 09:10 PM
magyar86's Avatar
haha if you pay more that 5k for what i listed then im sorry for you....
Old Sep 17, 2009 | 10:39 AM
TalonTuner4G63's Avatar
You don't have much mods, why would you want to tear apart a perfectly good running engine?
Old Sep 23, 2009 | 08:14 PM
MOREPSiTEHBETT4's Avatar
or buschur shortblock, whatever. Both are bomb Little minor cheap clean up on the heads and gasket match
Old Sep 24, 2009 | 08:53 AM
linuxman51's Avatar
save it for now, I've got 95k on mine, ams 35r kit has been on the car for .. almost 60,000 miles. Still stock block, no wierdness. I am eventually going to probably get a buscher stage 3 2.0, just to not have to mess with it.
Old Sep 25, 2009 | 10:01 AM
SBR Inc2's Avatar
I have a few shortblocks to chose from depending on the power you want to make and if you wanna stay with a 2.0. If you are interested in discussing some options please PM me.
