honey comb @ 28 psi
Old Sep 15, 2009 | 12:11 PM
Gary@MellonRacing's Avatar
Originally Posted by TTP Engineering
It screws up your MAF reading without it. Idle will be poor. I would suggest finding a replacement and epoxying it in there.
scott is this even if u have the car tuned after the honey comb is out ????
thanks scott
Old Sep 15, 2009 | 01:14 PM
DS-03evo's Avatar
Originally Posted by 4G63 T
This happened during spirited driving...
Almost sucked by 50 trim/ 35r hybrid turbo on 2.3 stroker.,
Now, im drivining without honey comb...
Is it safe?
Tommy,
That turbo has been know to be a MAF killer. lol
I had to epoxy mine in because the same thing happened with it.
How is the car running??
Old Sep 15, 2009 | 03:46 PM
4G63 T's Avatar
^ hey, nice to hear from you..
That sucker (turbo) performs well but the thing is need to upgrade head and intake manifold.
I been driving 40miles now without problem, idle unchange.
i plan to keep it off for good unless some1 here convince me otherwise.
Old Sep 15, 2009 | 05:08 PM
DS-03evo's Avatar
cool man
I actually tried to drive the car a bit with it off when it happened, but the AF ratio was all over the place. So I did not want to chance it.
I'm so missing all that power from that turbo. Rolling with the stock turbo for now..lol
It freaking dies after 5K rpm with the 2.3... hehe It's fun down low though
Old Sep 15, 2009 | 05:17 PM
Macaroni's Avatar
Speed Density FTMFW!
Old Sep 15, 2009 | 05:20 PM
Domolution's Avatar
That looks amazing! BAHAA!!!
Wow...wah dah pak happened!?! :X
Old Sep 15, 2009 | 05:38 PM
Weezy03's Avatar
What did it do when this happened. J/c since I am on 30-31 psi on a T67 and havent touched my honey comb
Old Sep 15, 2009 | 07:04 PM
GTijoejoe's Avatar
jeez, good thing your TB stopped it
Probably in your best interest to get another, of course you know its to direct the flow over the MAF, or the reading can get crazy
Old Sep 15, 2009 | 07:09 PM
detroit pistins's Avatar
I think u will be fine driving without the honey comb, all what it does; is it straightens the air going into the turbo ( laminar flow).
gl
Old Sep 15, 2009 | 07:37 PM
4G63 T's Avatar
gl
I kinda agree with you last 2 days i been playing around and afr seems unchange during idle and wot...but again im no expert dont know if there is adverse effect on the car per se.
Old Sep 15, 2009 | 07:42 PM
I actualy use honeycomb at work but on a larger scale, and the only purpose we use it for is to convert a gas flow from turbulent to laminar.
also, think of the guys that run the forward facing turbo setups, i don't remember seeing them using it.
Old Sep 15, 2009 | 08:51 PM
94AWDcoupe's Avatar
Originally Posted by DS-03evo
cool man
I have driven cars with AFC which monitors live karmann count. the karmann count goes nuts with taking even just half the combs out. A/F going all over the place is exactly what does happen when combs is removed. The people who drive with out them and dont notice any issue are either not very observant , not running wideband, or are running a wide band that doesnt update fast enough to see it.
Old Sep 15, 2009 | 08:56 PM
4G63 T's Avatar
"A/f going all over the place" are you also reffering on WOT?
Old Sep 15, 2009 | 09:29 PM
DS-03evo's Avatar
Exactly what I saw when logging the zeitronix. A/F ratio not where it should be relative to throttle input weather it be in or out of boost.
I would not take the car WOT way to risky, or boost at all for that matter.
Old Sep 15, 2009 | 09:35 PM
red evo8's Avatar
Originally Posted by ttp engineering
it screws up your maf reading without it. Idle will be poor. I would suggest finding a replacement and epoxying it in there.
+1
