ETS Mitsubishi Evolution 8/9 Custom Vertical Flow Intercooler
Old Sep 16, 2009 | 03:26 PM
ETS Michael's Avatar
The intercooler core is 10" tall , 23.5" Wide and 4" thick!! This is one of many custom coolers we build in our shop. This is setup to handle 800whp
Thanks!
Michael
Old Sep 16, 2009 | 04:48 PM
dsm25psi's Avatar
sick ETS FTW
Old Sep 16, 2009 | 04:52 PM
MitsuJDM's Avatar
Any chance it'll be put into production? What's it look like with the bumper on?
Old Sep 16, 2009 | 04:56 PM
xX v0oDo0 Xx's Avatar
Holy Moly Donut Shop!! Excellent product, another go at short route vertical intercoolers... Full-Race had tried something out, but stopped offering the product through their website (who know?).
Question: Is your ETS Upper Intercooler Pipe designed with the stock battery in mind? I have an Optima, and I don't really want to run a battery relocation. I know you guys offer this EXACT product for the horizontal intercoolers, but I imagine different piping will have to be used for this setup. From everything else I've read, the spool is helped out with a vertical intercooler too BTW, thanks again.
Old Sep 16, 2009 | 04:57 PM
N33d4sp33d's Avatar
will this be direct bolt-onto an evo 9 ?? Ne fabrication required to crash beam, bumper etc ? You guys r selling these units, how much ?
Old Sep 16, 2009 | 05:10 PM
This unit is 100% custom, we can build another one.. but the bumper will require a bit of trimming on the top and the bottom and the crash beam will need trimming or removed. This is a complete custom build, i'm sure we will see pics up shortly.
I can build this unit in a 3.0" and 3.5" that will fit a little better. The vertical flow needs to be thick to do the shop.
Thanks!
Michael
Old Sep 17, 2009 | 05:55 PM
racer135's Avatar
Horizontal has more travel to cool off on the Evo bumper. Which design is better? I thought horizontal was better due to the longer travel on the core.
Old Feb 10, 2010 | 12:32 PM
I wonder if the customer has any updated pics.. hmmm
Old Feb 10, 2010 | 04:27 PM
Mike.p's Avatar
what would something like this run price wise to have it built?? in either the 4" or 3.5"
Old Feb 10, 2010 | 04:35 PM
06MREvo's Avatar
So what would be the point of this? "UICP" will be shorter but the "LICP" will be longer...any pics with the piping installed/bumper on??
Old Feb 10, 2010 | 04:38 PM
Boltz.'s Avatar
FCOTM Winner
Vertical flow means more bars to flow across, so although the charge air spends less time moving through the core there are more bars to heat up. Also comparing both types of cores, if they have the same area, they have the same cooling capacity. The advantage of vertical flow is that you have less pressure drop and it will flow more. Better spool up, more torque because better spool, better response etc
Old Feb 11, 2010 | 04:38 AM
lekonna's Avatar
looks intresting,
wheres the other exit, whats the thickness of the runners and whats the size of the piping going in and out from the IC?
Old Feb 11, 2010 | 12:53 PM
The 4.0" thick is $1020.00 and the 3.5" is $920.00
Thanks!
Michael
Old Feb 11, 2010 | 05:26 PM
Tonba's Avatar
^ Pictures of the piping?
Im interested in a setup for my car.. What are the benefits?
At the moment Im running a Trust Spec-M cooler, with 3" custom piping.
Im about to order your short length upper intercooler pipe to try and help with spool, but I would be interested in the cooler + pipes.. How much? Is it worth the cost of changing it over?
ETS Michael
59
Nov 18, 2010 05:12 PM
ETS Michael
18
May 8, 2010 11:22 AM
ETS Michael
ExtremeTurboSystems.com – WA
Mar 8, 2010 09:12 AM
ETS Michael
19
Sep 9, 2009 05:48 PM
ETS Michael
16
Mar 27, 2009 09:12 AM
