Boost leak help
Old Sep 17, 2009 | 12:21 PM
brokenRS's Avatar
Boost leak help
I ran a boost leak test and i was leaking in the TB. Got the mil.spec one in, now that every time i turn my wheels my idle goes up and down a little. What could cause this?
Tien
Old Sep 17, 2009 | 02:18 PM
brokenRS's Avatar
up, trying to get my car running correctly today.
Old Sep 17, 2009 | 02:23 PM
Evoardo IX's Avatar
did you touch the TPS at all? if all you did was take TB out, replace gasket and put everything back then your problem is not related to the TB, I think all cars do that when you turn the wheels because power steering is belt driven so it takes power from the engine to help you turn the wheels
Old Sep 17, 2009 | 05:11 PM
boostedwrx's Avatar
Are you doing this while idle? Thats normal..
Old Sep 18, 2009 | 06:01 PM
brokenRS's Avatar
I got the issue resolved. But another one came up.
When the A/C is on, from being in gears to going back to neutral my car would shut off. The RPM would be really unsteady. When AC is not on, everything is solid.
So i guess there is something wrong with the AC lines, anyone have any hints?
Old Sep 18, 2009 | 06:38 PM
bbyevo8u's Avatar
^^ do you have cams?
Old Sep 18, 2009 | 09:02 PM
brokenRS's Avatar
Yeah, GSC exhaust cam on an evo 9.
Old Sep 18, 2009 | 09:23 PM
buchnerj's Avatar
The cams are obviously going to mess with your idle a little, you had it tuned after the cam install, correct? Might need them to adjust the tune a little, or try adjusting the idle on the throttle body...
Carter19
11
Apr 30, 2010 08:32 PM
freakitgood
Mar 19, 2009 12:13 AM
Fast_Freddie
20
Oct 15, 2008 08:28 PM
BCOZEVO
Aug 10, 2008 10:10 AM
