Ebay/Custom made Straight pipe.
Old Sep 19, 2009 | 09:59 PM
Nastynine's Avatar
idk im thinkin about it. i might just throw a few more bucks in and get a cut out welded into an aftermarket test pipe with a o2 housing and downpipe. keep my stock catback on so when i close it its nice nd quiet
Old Sep 19, 2009 | 11:21 PM
Dragking2189's Avatar
I bought this exhaust system from ebay when I was stock turbo and I had it for 11k and no problems, all you do is cut out that tip and weld a good tip like hks ti anything you like and trust me is not loud at all sounds like any other evo would sounds with turbo back exhaust
Old Sep 20, 2009 | 06:29 PM
Nastynine's Avatar
werddddd
Old Sep 20, 2009 | 06:53 PM
Piro Fyre's Avatar
It may sound the same but the quality of it is still bad. Everything is seized on mine and if I want to remove the exhaust, I would have to remove the whole TBE. From downpipe to muffler. It's also a matter of time before the chrome starts chipping off and then rust starts happening along with holes in the TBE system.
If you do go the eBay route, I WOULD NOT use the bolts that the eBay kit will give you. Go to a hardware store and buy the stainless steel versions of the bolts that you got from eBay and put anti-seize on them, then slap it together.
Old Sep 21, 2009 | 12:57 PM
Nastynine's Avatar
actually funny you said that, i was thinking about spraying the whole exhaust with the black heat resistant spray. not really with intentions to retain heat but more to protect the exhaust and slow the process of corrosion
mchuang
Aug 31, 2011 08:43 PM
mmartahus
Feb 3, 2011 01:08 PM
andymilonkis453
Oct 6, 2009 07:34 PM
MitsuOZ
13
Aug 25, 2009 07:21 PM
QwikEVO
Jun 3, 2009 02:25 AM
