clutch master bango bolt, How do you tighte /loosen??
Old Sep 21, 2009 | 04:55 AM
xspsi4's Avatar
I can't get a wrench or a socket in there, My ss braided line is leaking at the banjo and causing all types of shifting problems since air is now in the system and I can hardly fit my big bear claws down there
I know there is a method that I am not thinking of, I just wan't to tighten it to try to fix the leak.
Old Sep 21, 2009 | 04:56 AM
xspsi4's Avatar
I should mention I tried a ratcheting 14mm but there is just no room to get any clicks.
Old Sep 21, 2009 | 09:27 AM
mini_evo's Avatar
If you have an extra wrench laying around, cut it in half (or to the length you need, thats what I did. Also helps if it is a 12pt. not a 6pt.
