Evo 9 MR tranny
Evo 9 MR tranny
First off, has anybody experienced failure with the tranny bell housing? It appears as though the part of the housing that the pin for the clutch fork slides into broke off the housing. I've just got an ACT nothing major and no major HP mods. Was wondering if this has happened to anybody else. As a side, I'm wondering if the 6 speed tranny is the same across the evo 8 - evo 9 line? Can I put a 6 speed bell housing from an evo 8 MR onto a evo 9 MR tranny?
FWIW: I wasn't even racing when this happened. I was in the drive-thru line at DQ for an ice cream when I went to put it into 1st to move up, i heard a *ping* and the clutch pedal went to the floor. Needless to say, I never got my frozen treat
As far as I know, there is no difference between the Evo 8 and 9 gearbox cases. Only the gearsets have been changed from 5 to 6, but unfortunately for the Evo 9 owners, using the same case. So, if you can, you might want to swap with a 5 speed Evo 8 gearbox completely...
[WTB] 5 Speed Bell Housing
FL_SilverEvo8
Oct 16, 2016 06:07 PM
evo8vz
Oct 16, 2016 05:18 PM
2006IXWW
Oct 12, 2015 06:41 PM
