How much power does a down pipe add?
Old Oct 17, 2003 | 04:24 PM
03EVO8's Avatar
How much HP does a 3 in down pipe add on a mildly tuned Evo?
I have a UR 3 inch Catback and was considering a down pipe before doing a ECU reflash such as Visnu's Xfash when it is available. Is the DP worth it in this case?
Old Oct 17, 2003 | 07:16 PM
umiami80's Avatar
ALOT< ALOT of power, BIG difference. Get a 3.0 turbo back NO CAT. 30+WHP, maybe even more with tuning, and a TRUE topend, your turbo will love you for it, but make sure you have an Intake, better bov, MBC< and tuning before this mod.
Old Oct 17, 2003 | 09:33 PM
03EVO8's Avatar
It seems like the stock DP with no CAT would make more power than a 3in DP and high flow cat. True?
Like I said, I don't want to do a tone of mods. Just the exhaust and an Xede or Xflash. Shiv doesn't have any maps for a test pipe, so I need to road trip for a custom tune or do a better match of his tested mods. Which takes me to a DP decision. I figured I would loose some power by putting a cat back on but would get some of it back with the DP.
Old Oct 18, 2003 | 12:59 AM
shiv@vishnu's Avatar
FWIW, I do have maps for test pipes. For both Stage Zero and now Stage 1. Even if I didn't, it wouldn't be the end of the world running a non-test pipe map with a test-pipe. The most you may have to do is dial back the boost map a bit to prevent overboost/spiking.
Cheers,
Shiv
floating doc
Jan 18, 2017 11:29 PM
real fast
Dec 7, 2016 09:11 AM
evobroker
Apr 15, 2016 04:59 AM
SOLIDEVOX
Jan 31, 2015 05:56 PM
Darewood
Jun 3, 2012 03:17 PM
