*i Need Help Have A Problem With The Car Missing*
Old Oct 17, 2003 | 06:38 PM
evorespect's Avatar
WELL I HAVE MY BUDDIES EVO BECAUSE HE WANTED TO INSTALL nos kit but picked up the car and found it was missing under Load and at wide open throttle
i am thinking it might be a fuel deal
because at half throttle it doesnt miss
any help is appriciated
THANK YOU
Old Oct 17, 2003 | 07:43 PM
JeffWels's Avatar
assuming you mean misfiring? you need to clarify what your talking about.
If its misfiring check plugs for being fouled and check plug wires.
you need to be more specific, was it a wet system that was installed?
Old Oct 18, 2003 | 12:37 PM
evorespect's Avatar
there is no nos on the car at this point
at full throttle it seems to missfire at about 5 to 6 grand
i checked the wires and was going to but in some colder plugs for the nos
the car has a after market blow off valve on it
i think that the stock one should be put back on i ve been told that they dont do anything
thank s for the help
Old Oct 18, 2003 | 12:44 PM
WILDMAN's Avatar
Mine was doing the same thing. I replaced my plugs with NGK BPR7ES plugs (cooler plug) and mine runs great now.
Old Oct 18, 2003 | 12:51 PM
sr20det91's Avatar
.......except make your car run ruff. What type of BOV is it? There a few brands notorious for creating stalling issue. Sounds like that that may be the culprit. However, I have never seen a BOV make a car miss at high RPM like you describe. I would start by reinstalling the stock unit and take it from there.
BTW..If you put in colder plugs make sure you gap them correctly or you will experiance similar probs. I believe they should be around .28 or so. You may wanna do some research and check that your self though.
