HELP!!! Torque tube broke do I need to pull the whole tranny to replace it. Help!!!!
Old Sep 26, 2009 | 01:15 PM
TheMadScientist's Avatar
So had some issues with the car thought the front diff took a **** on me. I pulled it out and it looks fine however I discovered this. My question is can I remove the torque tube and replace it with the trans in the car?
The Differential:
Inside the transmission:
Old Sep 26, 2009 | 01:27 PM
sho669's Avatar
if you twisted the output off then the splines in the diff are probably damaged too. how far in did the tube break?
Old Sep 26, 2009 | 01:30 PM
sho669's Avatar
this must be related to your previous thread i'm guessing?
Old Sep 26, 2009 | 01:34 PM
wow fast reply. I posted pics right after so you all can see the problem
Old Sep 26, 2009 | 01:41 PM
sho669's Avatar
i would deff have the diff looked at. i broke mine like that and had to do both.
Old Sep 27, 2009 | 12:50 AM
Just pull the diff apart as well? I may as well get another then also while I'm at it.
Old Mar 22, 2010 | 01:13 PM
SeeCoryRun's Avatar
any update on this?
stockEVO_8
Oct 25, 2008 03:23 PM
antics22
Mar 29, 2008 11:45 PM
*chris*
Mar 28, 2007 09:31 AM
trinydex
Mar 24, 2007 12:24 PM
stockEVO_8
Oct 16, 2006 02:10 PM
