found this under my hood!!
Old Sep 26, 2009 | 06:49 PM
bbyevo8u's Avatar
can someone please tell me what this is, i found it sitting next to the drivers side headlight? is it my stock boost control?
Old Sep 26, 2009 | 06:50 PM
Evo9tunerz's Avatar
Yes it is your stock boost solenoid.
Old Sep 26, 2009 | 06:59 PM
project_skyline's Avatar
I'd just unplug it, since its not capped off.
Old Sep 26, 2009 | 07:05 PM
Evoryder's Avatar
no. leave it plugged in and loop a hose over the 2 nipples
Old Sep 26, 2009 | 07:14 PM
EvoLutionized8's Avatar
+1^^
Old Sep 26, 2009 | 08:27 PM
bbyevo8u's Avatar
whats the reason for that?
Old Sep 26, 2009 | 10:01 PM
metal4all6's Avatar
I think your check engine light will come on if you unplug it. I just have mine zip tied out of the way.
Old Sep 26, 2009 | 10:06 PM
ksattic's Avatar
Stops crap getting in the holes if you ever decide to go stock again.
Old Sep 26, 2009 | 10:46 PM
Slo_crx1's Avatar
It definitely will throw a cel if you unplug it. Just cap it off and leave it tied up.
Old Sep 27, 2009 | 12:43 AM
I've done it on 3 evo's. None threw a CEL.
Old Sep 27, 2009 | 01:07 AM
gsrboi80's Avatar
Hallman MBC have the ports looped and still pluged in
Old Sep 27, 2009 | 01:33 AM
krazykorean84's Avatar
Disconnecting mine threw a CEL. Leave it plugged in and tied out of the way if using a manual boost controller, or use ecu boost control with an updgraded solenoid.
Old Sep 27, 2009 | 09:01 AM
bbyevo8u's Avatar
thanks guys!!
this is off topic but maybe someone can help me with my shifter problem also? i didnt drive my car for like three days and out of nowhere my shifter became really really stiff in neutral when moving it side to side and when shifting from 2nd to 3rd i have to pull the shifter back in the center before i shift cause it will be stuck to the side or if i take it out of 1,2,5,6 or reverse the shifter will just be stuck to the side cause its soo stiff, i have a hard time getting into reverse now so i really need to fix this problem. has anyone ever had this happen to them and how did you fix it?
Old Sep 27, 2009 | 09:24 AM
gsrboi80's Avatar
Yea my car does this too. Havent checked it out caus it loosens itself back up eventually.
My guess is it's in the shifter base. Likely silicone spray will help
Old Sep 27, 2009 | 09:35 AM
Lukelis's Avatar
You have to leave it plugged
