found this under my hood!!
Old Sep 27, 2009 | 11:31 AM
bbyevo8u's Avatar
Originally Posted by gsrboi80
Yea my car does this too. Havent checked it out caus it loosens itself back up eventually.
My guess is it's in the shifter base. Likely silicone spray will help
mines does not loosen up at all and it takes me at least 5min to try and get it into reverse
Old Sep 27, 2009 | 11:42 AM
Spoolin' By U's Avatar
Definately a boost control solenoid. Got a little loose there huh?
Old Sep 27, 2009 | 12:31 PM
delongedoug's Avatar
Mine is not plugged and I don't throw a CEL.
Old Sep 27, 2009 | 12:35 PM
LGrady31's Avatar
leave it plugged in
Old Sep 28, 2009 | 10:04 PM
shrtstuff89's Avatar
mines got the hoses running back towards the turbo, seems to be where it heads. if you unplug it does it give any more psi? or less? same?
Old Sep 28, 2009 | 10:15 PM
scumrat's Avatar
GEEZ!!! EVERYONE READ THE THREAD BEFORE POSTING!!!! THERE ARE LIKE 20 OF THE SAME RESPONSES ALREADY!!!! OP in regards to your NEW question which everyone has failed to notice, it is probably your synchros going bad, that is the reason for your shifting problems.
Old Sep 29, 2009 | 04:47 AM
bbyevo8u's Avatar
^^ thanks
i no longer can get into reverse
Old Sep 29, 2009 | 05:54 AM
gsrboi80's Avatar
Try adjusting the clutch rod out a little. See if that help getting it into reverse. Seen this on a couple cars with new clutch installs. But still worth a shot
Old Sep 29, 2009 | 07:29 AM
bbyevo8u's Avatar
^^ the shifter doesnt move anymore
Old Sep 29, 2009 | 12:38 PM
evo unknown's Avatar
Yes that is the OEM BCS, cap the two ends. Do not unplug it.
Old Oct 1, 2009 | 09:26 PM
LGrady31's Avatar
stock boost controller// loop the hose from the two nipples
Old Oct 2, 2009 | 09:44 AM
_des_'s Avatar
Originally Posted by krazykorean84
Disconnecting mine threw a CEL. Leave it plugged in and tied out of the way if using a manual boost controller, or use ecu boost control with an updgraded solenoid.
X2 thats what I did. Seems to be working well with no check engine light.
marco4089
Jul 9, 2016 11:02 AM
omgivec
40
Jun 25, 2009 09:55 PM
billsav
Apr 18, 2009 12:31 PM
bartek
Nov 28, 2007 11:20 PM
