Downpipe rub: Get tie rod spacers or kart boy hangers?
Thanks for all of the tips! I was just about sold on the Kartboy route, but now I think I will try the longer bolt idea with the square nut.
Do you know what size the head is, and the length you decided to get? I am trying to get all done in one shot to the store.
Also, does anyone know why this has all of a sudden become an issue? Anyone have any insight to that?
I have a little rattle too that sounds like exhaust, so i went out and checked to see if my down pipe was hitting, but the brace was not on my car :-/, previous owner must have removed it....
I noticed that now the exhaust makes noise immediately after I start the car up and slightly rev it a little bit repeatedly.
I got down on my knees and looked under the car while pushing the accelerator off and on. I saw that the exhaust, mainly the middle to rear section, moving pretty dramatically with each time I revved the engine and causing a noise. As the car warmed up, the noise went away while revving.
So, I think that the noise is not coming from a downpipe - tie bar vibration.
I have decided to go with the kartboy hangers and see where that takes me.
Ok so the culprit was actually the connection from the downpipe to the testpipe. Somehow one of the two bolts backed out causing the two pipes to vibrate. I tightened that up and then replaced only two of the 5 exhaust hangers with kartboy ones.
By the way I'm not sure how anyone has gotten all five of theirs on; the rubber is very stiff making it very difficult to actually put them on. But even replacing just two of them I can notice a difference. Thanks for all the input guys!
