Downpipe rub: Get tie rod spacers or kart boy hangers?
Old Nov 30, 2009 | 02:03 PM
  #31
SyZyGy1394's Avatar
Originally Posted by EvODavO
Get 3 longer bolts and place a nut as a spacer beween the tie bar and the chasis. As you can see in the pic it leaves enough clearance for the aftermarket downpipe and is a verry cheap and effective solution to your problem.
Anyone know the thread pitch for those bolts? and length? Cause my downpipe is slightly touching and I am even using washers to space it out, but I don't want to run out of thread on the bolts.
Old Nov 30, 2009 | 02:11 PM
  #32
mifesto's Avatar
Besides exhaust hangers, worn engine mount bushings can cause it however unlikely for an '05. Also wrap your DP with heatwrap, in addition to the other advices
Old Dec 7, 2009 | 10:32 AM
  #33
krisdlm's Avatar
bump this, what size are the bolts for the oem tie bars?
Old Dec 7, 2009 | 12:52 PM
  #34
SyZyGy1394's Avatar
I just went out and bought some a few days ago. I got enough to do both braces.
This is what I got...
(5) Hex nut 10mm-1 25
(5) Hex bolt 10mm-1 25 x 35mm
(5) Lock washer split ring 10mm
I also used some stainless washers that I had on it before, maybe pick up some of those too. Using the nuts as spacers works well. The only thing was that those nuts, bolts, and lock washers cost like $14!
Rossi_24
Nov 21, 2018 11:59 AM
Fizylftingdrnks
Jul 29, 2016 11:31 AM
Tayhan
Feb 26, 2016 11:46 AM
porsherules911
10
Aug 9, 2008 01:45 PM
Por2geezSupra
Dec 9, 2007 10:59 PM
