Oil Pressure Reading
Old Sep 28, 2009 | 01:01 PM
sdfontanini's Avatar
I installed an AEM Oil Pressure gauge on my cylinder head right, as seen here:
The highest the pressure is reading is 32 PSI, is this normal or should it be reading higher?
Thanks
Old Sep 28, 2009 | 01:03 PM
evojoe90's Avatar
idle or in the rpm range
meckert's Avatar
You need to be reading off the block--which would read around 80-100 psi cold. You likely have a restrictor in the head to keep pressure managed so you dont over oil the cam and lifters causing other issues.
