Idle Problem and Throttle Lag
Old Sep 30, 2009 | 04:31 PM
Huntington MR06's Avatar
Here is a video of how my car acts up... (sorry for crappy camera phone video)
also in the video i never touch the throttle at all...
http://smg.photobucket.com/albums/v2...VID2000013.flv
this happens randomly and isnt all the time
i will be driving and when i take the car out of gear in to neutral the rpm's will hang at 2k or 1,500 then when i come to a stop it will drop down to 1,100-800rpm.
i believe my timing at idle is at 8 or 9. and my TB screw has been adjusted. the sudden drop in RPM and my car almost stalling happens sometimes.
also
when im at a stop and release the clutch it tries to die on me and i have to give it more gas than i should and then the throttle will kick in.
anyone have any problems like this before?
i had a XS ignition box hooked up when i got tuned and it took a crap on me and i disconnected that and im running the stock ignition now.
Old Oct 3, 2009 | 07:28 PM
anyone?
plugs were checked a few weeks ago n they were fine.
Old Oct 3, 2009 | 09:50 PM
TommiM's Avatar
Have you physically checked your throttle cable? Check to make sure its adjusted right, along with all the brackets that are on it. Open and close the throttle plate and see if it gets hung up somewhere.take the pipe off and look inside while you are moving it to make sure its ok. a good visual inspection is always a good start.
ilive2win
10
Jul 10, 2009 02:57 PM
ilive2win
63
Sep 25, 2008 05:23 AM
2MucHP
Oct 29, 2007 01:36 PM
Jasil
Oct 15, 2007 07:17 PM
Ninj0x
16
Jun 13, 2006 11:50 AM
