Rear Differential
Old Oct 18, 2003 | 04:48 PM
evosevengsr's Avatar
Rear Differential
recently replaced my rear differential.
but now the one i have makes this noise.
when changing gears like from 1-2,2-3.....you hear this loud knock from the back diff..
anyone have any ideas on what the problem can be...
Old Oct 18, 2003 | 05:01 PM
maki's Avatar
why did you have to replace your stock diff?
i hear some knocking when shifting from 1-2
Old Oct 18, 2003 | 05:38 PM
got into an accident and my mechanic advised to not take the chance and use the old diff as I may see problems later on.
so i replaced it.
the noise is really scary though.it makes me drive slow cause it sounds like something could break
Old Oct 18, 2003 | 06:13 PM
1QWKEVO's Avatar
I see ur running an Evo VII, did you install the rear diff with YAW? Or did they open up the diff and change gears and what nots..?
Old Oct 19, 2003 | 10:19 AM
yeah....installed the rear diff with AYC.
Old Oct 19, 2003 | 10:40 AM
SilverEvo8owner's Avatar
hmmm
i dunno
if you have the old try putting it back in
Old Oct 19, 2003 | 10:51 AM
992gnt's Avatar
Check the u-joints, sounds like one of them is done for.
Old Oct 19, 2003 | 09:23 PM
thanks guys...
will check the u-joints and if that doesnt work out the last resort would be to try the old one...
Old Oct 19, 2003 | 09:43 PM
90GSX-03EVO's Avatar
Improper lash/backlash adjustment. Your pinion to yoke gear tolerances are probably too great. It needs to be checked with marking compound on the gears to verify proper gear contact.
If that sounds like a foreign language to you, your mechanic will know what I am saying. Just print it out and show him.
Hope this helps,
Old Oct 20, 2003 | 10:02 AM
it is foreign to me...
will show it to my mechanic.
thanks josh
Old Oct 20, 2003 | 03:22 PM
No problem.
