Mysterious Boost Leak Under Intake Manifold
Old Oct 2, 2009 | 05:44 AM
kmcconn9's Avatar
Question Mysterious Boost Leak Under Intake Manifold
*Update, see bottom of page 1 for updated information/question.
I recently did a boost leak test, and I can hear air coming out from what seems to be under the intake manifold. A more precise location would be the bottom right side of the IM (from looking into the engine bay).
  • I checked the injector o-rings - not leaking
  • I checked the egr hoses on the back of the IM - not leaking
  • I checked the hoses on top of the IM - not leaking
  • I checked the connections around the Perrin fuel rail - not leaking
  • I checked the TB Shaft seals - leaking, but makes a different sound when I move the throttle cable, so its not coming from here. (Getting replaced by CBRD w/ Mil Spec Seals)
I cant reach back behind the intake manifold to see where it is coming from.
Has anybody else heard a leak back here? I can get it to 15psi, and then it will drop off after removing air pressure.
One thing to note, is a do have a slight head gasket leak on the back side of the motor. Could the leak be coming from this? My original though was, "if it's leaking oil, then its leaking air". The head gasket leak was caused by a 1x1 head stud install (Pruven Performance).
Thanks for the insight guys.
Old Oct 2, 2009 | 08:07 AM
kmcconn9's Avatar
The head gasket is getting replaced here as soon as I can get an appointment with CBRD, so we will find out if this is causing the leak soon enough.
But I wondering if anyone else has run into this issue, or if a leaking head gasket could cause a boost leak.
AFR's are more stable now with the bov and vaccume T leak fixed. It wouldnt even get past 5psi with those leaking...
Old Oct 2, 2009 | 08:10 AM
AlwaysinBoost's Avatar
I had the same type of leak and it turned out to be a solenoid under the intake near the TB... I think it was the ERG but that was like 3 years ago so I'm not 100% sure.
a good way to find a leak if you know the general area its in is to pressurize the pipes like normal then wet your hand and stick it back there feeling around for the air. you will feel the air better when your hand is wet then when its dry. hope that helps.
Old Oct 2, 2009 | 08:14 AM
AF-Evo8's Avatar
^^^ this solenoid is attached to the IM support bracket, i believe its the EGR solenoid. Check and see if that is where its leaking. I have big Shrek hands and i can reach it without removing anything so with a little work you could probably get a hand on it to check.
Old Oct 2, 2009 | 08:39 AM
kmcconn9's Avatar
Interesting. I will have to check that out. Does anybody have a picture of the back of the motor with the IM installed so I can get an idea of the location of some vacume connections/seals?
Old Oct 2, 2009 | 08:51 AM
kmcconn9's Avatar
Gotcha. Yea I am 6'6, I dont have small hands either.
So it must be right under the TB then from the sounds of it. I will check it out tonight. I might have to pull off the DC Ti strut bar though, that damn thing is always in the way.
Old Oct 2, 2009 | 09:20 AM
kmcconn9's Avatar
I assume this is what you guys are talking about?
Attached Thumbnails Mysterious Boost Leak Under Intake Manifold-100_7742.jpg
Old Oct 2, 2009 | 09:35 AM
what I'm talking about is on the otherside of the mani... you can't see it in that pic, you'd have to flip the mani upside-down
Old Oct 2, 2009 | 09:37 AM
AF-Evo8's Avatar
I'll post a pic in this response when i get home @ lunch of the sensor we're talking about.
Old Oct 2, 2009 | 09:47 AM
kmcconn9's Avatar
Excellent. Thank you.
Old Oct 2, 2009 | 03:46 PM
kmcconn9's Avatar
Man, you must have a late lunch...lol...j/k. It will be much appreciated when you upload the pic.
Old Oct 2, 2009 | 06:42 PM
KevinD's Avatar
check the EGR hoses again. the back side one pops off a lot and is very obvious. the front hose often times stays connected, but the hose itself splits right at the nipple on the EGR. its something that you can't tell without actually pulling the hose off and inspecting it. i've seen this hose split many times. the hoses on the solenoid are a good one to check as well.
Old Oct 3, 2009 | 05:51 AM
kmcconn9's Avatar
Yea, before I do a boost leak test, I always check the one of the back side of the TB. I actually put a zip tie on that basterd because it always pops off.
The one on the front, I will have to double check.
Thanks for the suggestion
Old Oct 3, 2009 | 06:23 AM
kmcconn9's Avatar
Are you referring to the top right egr valve?
Attached Thumbnails Mysterious Boost Leak Under Intake Manifold-img0081qv5.jpg
Old Oct 3, 2009 | 06:59 AM
kmcconn9's Avatar
ok, so this is weird, or bad. I am currently doing another leak test, and I think I have pinpointed the leak.
If I put my ear on the top of the valve cover, right by the top right bolt I can hear a leak.
Why/how would the leak be on the inside of the valve cover? Might this have something to do with the head gasket leak on the back side of the motor?
Maybe I should pull the valve cover and try to re-tq the head bolts to 85 ft lbs?
