4G64 120K engine service
Coming from DSM community forums to 3rd gen forums has been a nightmare. According to 3rd gen guys only the dealer should rotate my tires or chage my wiper blades.
Lucky for me 3rd gen 4G64 and evo 63 have so many simularities. Anyway, Im
getting ready to turbo a 2001 eclipse GS that has almost 120K
Ive got a list but i want to make sure i have all the gaskets as well. I will need the part numbers for everything for my rightup for the not so helpless 3gers. What are your thoughts on replacing the front main since im in there?
Balance shaft delete
MD098626 Stubby shaft to replace the left balance shaft
MD040597 Right balance shaft front bearing used to block the oil gallery
MD103722 Right balance shaft rear bearing used to block the oil gallery
MD092785 Plug to block off the right balance shaft provision on the front case
MD128107 Spacer to replace the crank shaft sprocket
MF140022 8 x 14 bolt to replace the balancer belt tensionioner
120k Timing job
MD366260 Oilpump
MD322521 Front case gasket
MD976464 waterpump
MD336149 Timing belt
MD182537 timing belt tensioner
MD156604 tensioner pulley
Thanks a lot guys
120k Timing job
MD366260 Oilpump
MD976464 waterpump
Thanks a lot guys
Can't help you with WHAT you need but I can help you by suggesting you purchase your parts at http://www.mitsubishiparts.net/ to place your order. Great prices and fast shipping too...
Hope this helps...
Hope this helps...
