Transmission Installation
Old Oct 2, 2009 | 10:57 AM
kmartizdatruth's Avatar
i'm putting my new shep transmission and rebuilt clutch in today anyone with a last few words of advice or tips to help me make things a bit easier tonight?
Old Oct 2, 2009 | 11:05 AM
DDATuned's Avatar
Drop the subframe. Makes the transmission and transfer case install a snap.
Old Oct 2, 2009 | 11:49 AM
antilag_200's Avatar
Make sure the washer is under the reverse sensor, otherwise the car won't go into gear in reverse and 5th.
I beleive the oem washer is between 48 and 50 thousands thick.
Old Oct 2, 2009 | 11:58 AM
thanks for all the info keep it coming
Old Oct 2, 2009 | 12:09 PM
Silver05Bullet's Avatar
good luck its a pain in the *** everytime i do one, if your doing it on jackstands jack both the front and back of the car to as high as you can that way the engine wont swing back when you pull the tcase out, also make sure you have someone help you, if you take the subframe down its alot easier but you will need an air gun to loosen those bolts, get yourself something to pull out the input shaft, also if the throw out bearing doesnt come out easy, you can unbolt the whole pressure plate by sticking a ratchet thru the whole where the fork goes in and spining the crank in many cases GOOD LUCK get some beer to it might turn out to be longer than you think
Old Oct 2, 2009 | 12:29 PM
delongedoug's Avatar
Don't drop the subframe. Get some friends to help and use a transmission jack. 3 of us got our friends' tranny in (from sitting on the ground to on the car) in ~15mins without dropping the subframe.
Old Oct 2, 2009 | 01:27 PM
overdrive1's Avatar
beers and pizzas...
Old Oct 2, 2009 | 01:56 PM
lemmysports2's Avatar
Originally Posted by overdrive1
beers and pizzas...
+1 on that.
this always helps me.... http://evomoto.com/tech_articles.php?tech_article_id=27
Old Oct 2, 2009 | 05:50 PM
Teal2nnr's Avatar
I love beer and pizza
Old Oct 2, 2009 | 05:59 PM
JakeTheVIII's Avatar
Yea don't drop the subframe. A lot of work you don't need to do.
JakeTheVIII
South Region
Jan 14, 2017 07:58 AM
Migsubishi
Jun 3, 2016 08:13 AM
MitsubishiJoe
Feb 14, 2014 07:57 AM
kashak
42
May 29, 2013 07:57 PM
Pro
Sep 18, 2007 02:15 PM
