Vent to air BOV question. Please help!
Old Oct 5, 2009 | 06:17 PM
Teal2nnr's Avatar
Meh, i like my forge I've personally never had an issue. I've herd good things on the Synapse bov as well, but never tried one so no comment on that.
Old Oct 5, 2009 | 07:09 PM
Babs's Avatar
Originally Posted by CMB
Thanks Babs for the response. Looks like it works for some and is a pain for others. Is your car tuned for it or you just put it on?
I slapped it on and that was the end of it. Haven't touched it since...
I, of course, got a 2.5'' UICP to go with it rather than reflanging the stock pipe.
What mods do you have done? I have full bolt-ons (no cams, clutch, or internals) and I'm using the -11psi spring. If you have a boost gauge, you need to determine how much vacuum you're pulling at idle and then you buy the spring for it depending on that. I'll see if I can find the chart for it.
EDIT: Here's the chart...
http://www.tialmedia.com/documents/w3_tial_bov50_sp.pdf
My boost gauge read -20 in/Hg at idle so I used the -11psi spring and, like I said, not a single problem.
araz5260
Nov 26, 2014 01:45 PM
evoo22
Jul 28, 2014 10:00 PM
lpy2009
Feb 26, 2012 12:09 PM
H'swwEVO
59
Jun 11, 2011 02:28 PM
sleepy_rps13
Aug 10, 2010 02:58 PM
