Ams downpipe rubbing tc ?
Old Oct 5, 2009 | 07:59 PM
mantosride's Avatar
So have a bunch of stuff on my car, have a full TBE from ams, well when we where tuning the car, we where getting all kinds of knock, tried and tried to get the knock to go away just would not, come to find out my down pipe under a load is rubbing up agasint the TC, you an see the mark clear as day, know just sitting there it looks fine clears no problem, not sure what to do any suggestions ? i am going to give AMS a call in the morning just wanted to see if anyone else had similar issues , and what they did to solve it
Old Oct 5, 2009 | 08:03 PM
detroit pistins's Avatar
suggestion: buy a thin flange (whatever u think might be needed to clear the tc), and sandwich it inbetween the dp flange and the o2 housing with 2 gaskets.......lol, here is the order
o2 housing
gasket
flange
gasket
downpipe
btw with the above u might start hitting the front lower bar, so u will probably need to space it out as well with a washer or so.
and...gl!
Old Oct 5, 2009 | 08:11 PM
mantosride's Avatar
Well that sucks , has anyone else had this problem ??
Old Oct 6, 2009 | 03:52 AM
mantosride's Avatar
anyone ??
Old Oct 6, 2009 | 06:35 AM
Andrew@AMS's Avatar
Is there anyway you can take some pictures of where the exhaust is rubbing? We have seen this issue when the testpipe, HFC, or high flow resonator is not installed properly. Which piece do you have? Also do you have any motor mounts installed in the car?
Old Oct 6, 2009 | 06:56 AM
gsrboi80's Avatar
Is it possible that you got a non ACD DP by accident????
Old Oct 6, 2009 | 07:48 AM
mantosride's Avatar
called ams , today they said that they are all the same pipe
Old Oct 6, 2009 | 07:57 AM
mantosride's Avatar
Andrew,
No I do not have any motor mounts, the area that is rubbing, is the down pipe, its rubbing right up against the side of the TC, it looks fine just looking at it, but in WOT the tc is rubbing up against the down pipe. the cat delete and the rest of the exhaust are fine . not sure what to do here !
Old Oct 6, 2009 | 08:57 AM
Andrew@AMS's Avatar
We really would need to see pictures of the downpipe on the car to see whats going on. It's weird that you say that it's fine when you are looking at it and at WOT it is rubbing causing noise. This leads me to believe that there is engine movement under heavy load. I would inspect the motor mounts for tearing or wear. The AWD puts a lot of stress on these mounts.
Old Oct 6, 2009 | 10:04 AM
mantosride's Avatar
Andrew,
I will have to inspect them, but the car is only making 430whp and its an 06 with 13k would be odd if motor mounts where moving, but you never know, is there anyway i can send you pics direct ?
Old Oct 6, 2009 | 01:53 PM
Andrew@AMS's Avatar
Yes, you can send the pictures to my email address in my signature.
Old Oct 8, 2009 | 05:18 AM
mantosride's Avatar
Andrew,
email has been sent
thanks steve!
Old Oct 9, 2009 | 08:42 PM
mantosride's Avatar
here are some pics guys if anyone has any good ideas let me know !
Attached Thumbnails Ams downpipe rubbing tc ?-dscn6243.jpg   Ams downpipe rubbing tc ?-dscn6248.jpg   Ams downpipe rubbing tc ?-dscn6253.jpg
mantosride's Avatar
Ttt
Old Oct 9, 2009 | 10:43 PM
mantosride's Avatar
anyone any ideas??
