Alcohol
Old Oct 19, 2003 | 09:37 PM
evosevengsr's Avatar
Alcohol
heard a few guys did this and they say it supposed to make a difference.any users?
I used ice in mine.Dont know if it makes a major difference but cooler is always better.
thanks
Old Oct 19, 2003 | 09:40 PM
SilverEvo8owner's Avatar
im not sure if its a good idea
its flammable and could eat away the rubber
windshield washer fluid should do just fine
Old Oct 20, 2003 | 06:11 AM
jemm's Avatar
Tap water 90%
and ethyl alchol - 10%
a few drops of vinegar.
edit : I don't know what distilled water costs in the states, but down here its a little too $ to be practical, so we add vinegar to the solution to prevent clogging of the lines by the minerals. If you don't want to mess with alcohol, some shaven ice and water does work before a run!
Old Oct 20, 2003 | 06:46 AM
aaronyoung's Avatar
The main reason for adding alcohol is to keep the water from freezing.
Old Oct 20, 2003 | 08:00 AM
Fireball's Avatar
You really don't want to use Tap water either. The small traces of minerals in the water will eventually clog the lines up. Used distilled water.
Also, the alcohol in anything you make will corrode the aluminum fins of the intercooler. recommends windshield washer fluid WITHOUT alcohol!
Your best solution for those spirited runs, is distilled water, with ice in the bottle.
