need help(alternator)
Old Oct 15, 2009 | 04:19 PM
PRican_480's Avatar
Im not really sure if its the alternator but at start up (idle) the gauges reads 14. within the next couple miles it will drop to 12.5-12.2 at idle but as soon as i get into higher RMP it reads 13.5-13.7 and as soon as i go back to idle it drops again if any can help it would be greatly appriciated thanks
Edit:
and all summer long it stayed at around 13.5 with headlights on, A/C , right up until i recently changed the battery and they checked the alternator and said it was fine so if any 1 know or has the same type of problem please share any helpful info
Old Oct 15, 2009 | 09:30 PM
Thomasevo's Avatar
never paid attention to mine i would think that it should be fine though man
Old Oct 15, 2009 | 11:00 PM
MitsuJoe's Avatar
Check the top battery post and make sure the positive cable is tight and the 12mm nut holding the alternator wire is also tight.
Old Oct 16, 2009 | 04:18 PM
PRican_480's Avatar
ok koo will do
Old Oct 17, 2009 | 09:50 AM
PRican_480's Avatar
any other suggestions?
Old Oct 17, 2009 | 09:52 PM
PRican_480's Avatar
bump
Old Oct 17, 2009 | 10:38 PM
dsmloverforlife's Avatar
Maybe its your gauges. If you have a volt meter check the the volts at the battery and make sure that it matches your gauges (I would recommend having a buddy there so it goes quicker). Check it at idle and around 2000-2500 rpm.
Old Oct 19, 2009 | 11:36 AM
MitsuJoe's Avatar
U say bump but dont say what you did or did not do. I can't help you with bump.
Old Oct 27, 2009 | 09:24 PM
PRican_480's Avatar
^^^ i did what you said and problem still remains any other suggestions?
detroit pistins
51
Jun 22, 2017 01:04 PM
turboevo8
Jan 20, 2015 04:44 AM
cky_bam_marg
Jul 11, 2014 07:28 PM
kliped
Jan 11, 2014 04:03 PM
MrBRoced
Lancer Troubleshooting
13
Dec 11, 2012 02:33 PM
