WEAPON-R oil Catchcan setup>>pics
Old Oct 15, 2009 | 04:59 PM
xhammerx's Avatar
HELP!!!!WEAPON-R oil Catchcan setup>>pics
jus installed it the other day? what u guys think?
the way its set up is it ok??
Attached Thumbnails WEAPON-R oil Catchcan setup>>pics-img00105-20091013-1857.jpg   WEAPON-R oil Catchcan setup>>pics-img00107-20091013-2117.jpg   WEAPON-R oil Catchcan setup>>pics-img00110-20091014-2208.jpg   WEAPON-R oil Catchcan setup>>pics-img00111-20091014-2208.jpg   WEAPON-R oil Catchcan setup>>pics-img00113-20091014-2208.jpg
Old Oct 15, 2009 | 05:07 PM
xhammerx's Avatar
some more
Attached Thumbnails WEAPON-R oil Catchcan setup>>pics-img00106-20091013-2116.jpg   WEAPON-R oil Catchcan setup>>pics-img00108-20091013-2117.jpg
Old Oct 15, 2009 | 05:13 PM
05VIII's Avatar
hmm im not to sure but i dont think thats ok.
Old Oct 15, 2009 | 05:40 PM
drop24's Avatar
Should look like this:
Old Oct 15, 2009 | 07:10 PM
xhammerx's Avatar
ok havin a lil trouble...i know where the left side goes from the oil catch can but havin trouble wit the right>>> ny one have a pic where the other one goes>>
Attached Thumbnails WEAPON-R oil Catchcan setup>>pics-img00110-20091014-2208.jpg
Old Oct 15, 2009 | 09:05 PM
evo unknown's Avatar
http://www.evomoto.com/tech_info.php...3_6&tech_id=21
this is the right way^^
Old Oct 16, 2009 | 04:36 AM
eTiLiKo's Avatar
It fit also o the cusco bar?
Old Oct 16, 2009 | 05:13 AM
I imagine it would fit the cusco bar. The two screws that connect the strut to the firewall is the only place where the catch can attatchs to and then just sits in the triangular section.
Old Oct 16, 2009 | 07:43 AM
dastallion951's Avatar
looks pretty weird for a setup considerin i have the cusco oil catch can n where mine is mounted in the place of the stock battery i would assume even under WOT conditions that the blowby coming from PCV might have a bit of trouble going up the hose to the catch can...some correct me if wrong....
Old Oct 16, 2009 | 08:56 AM
evo8inla84's Avatar
I dont believe you did the install correct but i will post pics of mine ASAP...
Old Oct 16, 2009 | 09:50 AM
xhammerx's Avatar
that would really help>>>thx i dont know where one of the lines go from where i mounted the filter on the catch can. theres is no trace back line hooked up cause all there were 2 breather hooked up to both sides lol..
Old Oct 16, 2009 | 06:08 PM
xhammerx's Avatar
Old Oct 16, 2009 | 08:04 PM
vtrice69's Avatar
well, the design looks clean. good luck with hooking it up right.
Old Oct 17, 2009 | 12:31 PM
the hose that connects to the passenger side of the catch can connects into the side of the block. the hose that connects to the driver side of the catch can connects into the intake pipe.
Old Oct 17, 2009 | 12:38 PM
xhammerx's Avatar
oh ok...the way its setup right now is it hurting nything?
