valve spring install question (without pulling head)
Old Oct 16, 2009 | 12:15 AM
jeri534's Avatar
So Im planning on installing some cams/valve springs on my IX, I dont want to pull the head so I was thinking of just pressurizing the cylinder and pulling the valve springs that way...
My question is, is there a way to lock the crank when doing this? Ill have the cams off and the belt ziptied to the cam gears, I dont want to pressurize the cylinder and push the piston down and rotate the crank. and throw my timing off
thanks
Old Oct 16, 2009 | 04:56 AM
barneyb's Avatar
Get yoursef a piece of steel about 2 inches wide and not sure how long (cut to length needed). Pull the accessory belt, belt tensioner and damper. Drill holes in the steel for the holes in the crank sprocket and a hole where the large bolt is for the tensioner and bolt the two up. Done.
Old Oct 16, 2009 | 07:27 AM
Bluefire's Avatar
as long as the piston is all the way to the top you shouldn't have to lock the crank... I've done this many times and haven't had an issue
Old Oct 16, 2009 | 08:02 AM
JakeTheVIII's Avatar
Do one cylinder at a time, put each cylinder at the top of the stroke so the valves cant fall in.
Old Oct 16, 2009 | 10:04 AM
PATRICK B.'s Avatar
Just like stated above no need for to lock the crank.
Depending on the valve spring compression tool you use i like to do all the exh side first and then tackle the int side after
Be sure to have a good magnet handy for the keepers and i alsolike to stuff rags down in the oil passages just in case.
Old Oct 16, 2009 | 10:49 AM
jeri534's Avatar
This is not possible if I have the belt tied up to the camshaft sprockets
Old Oct 16, 2009 | 11:40 AM
oops, completely missed that part.
What barneyb said sounds like it would work too
Old Nov 25, 2009 | 04:58 PM
EVO_MERLE's Avatar
can not find a installer to do it this way, looks like i am taking the head off my car
Old Nov 25, 2009 | 05:06 PM
fre's Avatar
fre
Just did that because I had a warped head, it will take a good 8 hours if you haven't done it before, but it isn't that difficult. The hardest part is that damn intake manifold bracket, which I purposely didn't reinstall hah. Bad part is you will need to replace the head gasket, but that's like 60-70bucks online.
Old Nov 25, 2009 | 05:09 PM
EVO_MERLE's Avatar
I just want my damn cams in before i deploy and don't get to play
Old Nov 25, 2009 | 05:18 PM
Aby@MIL.SPEC's Avatar
get the universal spring remover from snap-on.....was ~$80-
put the car in gear if your concerned about the crank turning....
i forget how much pressure i put into the cylinders, but i start low & creep up on the regulator to keep the valves from moving.
definately put paper towers into all the drain backs, as thats where 1 keeper will fly into if you dont!
Old Nov 25, 2009 | 05:21 PM
EVO_MERLE's Avatar
Anyone wanna make a road trip to sunny Pensacola,FL....Come on you know you wanna!
Old Nov 25, 2009 | 05:32 PM
fre's Avatar
fre
Would if I didn't live in Idaho hah. I know how it is being in the military, so I feel your pain.
It really isn't that hard to get the head off as long as you have two days to spare. Of course doing it without removing the head would be preferable. I had my buddy uninstall/reinstall the springs/retainers so I didn't have to put up with that hassle. I took the head off and removed the cams.
Old Nov 26, 2009 | 05:41 AM
barneyb's Avatar
I've done it with the head on the car. You need a spring compressor made for this application - not inexpensive.
The parts are tiny, it is not like working on a V8.
Old Nov 26, 2009 | 09:38 AM
nos51's Avatar
by this and do it yourself.......its made for the evo and work like a charm.it cheaper than the universal one and when you put a set of duels springs with the universal one its a real pita especially the intake side......
http://www.euroexportinc.com/product...ducts_id=44428
