Wideband readings.....
Old Oct 19, 2009 | 03:04 PM
jyndrus90's Avatar
So I installed my wideband and at 18 lbs my readings are in the 11s. Its 60 derees outside. My question is isn't that lean for a 05 evo with a tbe, o2 housing, intake and bc? The guy said I have a walboro 255 but now I'm unsure of that. The car is untuned. The wideband sensor is behind the testpipe could it be possibly too far?
Old Oct 19, 2009 | 04:47 PM
jyndrus90's Avatar
anyone?
Old Oct 19, 2009 | 04:58 PM
binky's Avatar
11's are fine. 11.1-11.4 is where you would want to be.
Definitely get a tune.
-Bink
Old Oct 19, 2009 | 05:21 PM
RSMike's Avatar
how come the norm for tuning is running rich?
i thought max power was made at 12.5 AFR?
why not run 12.5AFR and pull out timing as opposed to running more fuel and more timing?
And i know someone will say they run rich for "cooling" the cylinder... but how much difference can a couple of mls of fuel make?
Just wondering.
Cheers, Mike
Old Oct 19, 2009 | 05:38 PM
binky's Avatar
For Evo's 11.1-11.4 is not rich. It's right where it should be
Yes, gasoline makes the most power at 12.5 AFR - however the Evo's combustion chamber is not designed for such a lean AFR (keep in mind the 4G63 engine is almost 20 years old). The Saturn Sky is one of the only cars I know of that can run that lean, I believe it actually runs a 12.5 AFR.
-Bink
Old Oct 19, 2009 | 05:44 PM
t-revzr's Avatar
My car is at 11.1 im on E85 tho not sure if that matters...
Old Oct 19, 2009 | 08:15 PM
jyndrus90's Avatar
I still think somethings fishy why would mitsubishi make the car run so lean stock. I measured and I think my the wideband o2 is too far. It was like 60 in from the turbo. Anyone know if the 10 degree angle on the o2 that AEM recommends is necessary for accurate readings?
Old Oct 19, 2009 | 08:17 PM
evo@24psi's Avatar
My car has been at 11.7-11.8 for 50k+ miles now. 11.2 is on line of rich.
Old Oct 20, 2009 | 03:08 AM
RSMike's Avatar
not designed to run a lean AFR?
because it'll generate too much heat? or det issues?
i dont really see your point.
just trying to clarify what you're saying thats all
-Bink
Old Oct 20, 2009 | 03:23 AM
McLaren F1 2003's Avatar
isnt the sky a direct-injection motor? or no? IIRC, only direct-injection motor can run that lean
but to answer the original question, 11's are fine
but 12.5 is too lean for a boosted motor
Old Oct 20, 2009 | 03:31 AM
RSMike's Avatar
people in NZ and Aussie run 12.5 AFR for boosted cars all the time...
Old Oct 20, 2009 | 03:36 AM
Fast_Freddie's Avatar
Veteran: Navy
FYI the sky (redline) is direct injection, the woman has one...
As for running 12.5 AFRs... it all really depends on how you choose to tune the car... I run mine at around 11.5/11.6 tapering to 11.1/11.2 however there are a few tuners that like to tune a leaner AFR...
Old Oct 20, 2009 | 06:38 AM
97TSiAWD's Avatar
If this is on a gasoline wideband, that is quite rich for E-85. You can make quite a bit more power by leaning that out a little more. Even on pump gas, most people target ~11.5:1 A/F ratio. On E-85, I aim for 12:1 A/F.
Mitsubishi didn't; your mods probably did. The intake can throw off the MAF readings causing the car to run leaner, as well as the additional flow from the exhaust mods. And 11.x:1 isn't that lean, especially if it's in the low 11s.
Totally stock, the Evos tend to run as rich as 9.x:1 at WOT.
On what fuel? A lot of Evos here run 12.5:1 on race gas or E-85, but no one would want to tune for that on pump gas (which is what I assume the OP is using).
Old Oct 20, 2009 | 12:58 PM
RSMike's Avatar
In New Zealand there is 91, 95 and 98 Octane. most people tune on 98.
I'll be tuning my car for about 12.0 - 12.2 AFR when i get my Red from the states.
We leaned up a standard evo 8, from about 11.0 to 12.0 and picked up 30kwatw (40whp) without touching anything else. Running 98 Octane pump gas.
Old Oct 20, 2009 | 03:50 PM
jyndrus90's Avatar
I did sorta a custom intake since I got a 4in maf adapter and got a small 4 in filter. Should I leave that or put in the stock airbox for correct readings? I got a new bung welded in because my wideband o2 was like 60in from the turbo
