Stock Evo, different boost in each gear?
The ony modification on my Evo is an AEM intake. In first it goes to 19.5 or so then tapers to 16-17 lbs. In second about the same, but then in third holds about 18 lbs to redline and the same with forth. Is this normal? Does the stock ECU recognise what gear the car is in and hold boost accordingly? It does this time after time so I was just curious.
Boost
Yes, Your max and boost taper values are exactly what mine are. It is normal. I also think the ECU lets you hold more boost in the higher gears due to better intercooler efficiency at higer speeds.
Chad.
Chad.
06GraphiteEvoIX
Feb 1, 2012 06:32 PM
TURBODAWG
73
Feb 9, 2006 08:38 AM
