Not getting into gear!!!!
Old Oct 24, 2009 | 06:12 AM
06redrocket's Avatar
ok i have an 06 evo mr with a built 5 speed tranny from shep and a exedy twin disc clutch . I really know nothing about trannys but my car is having a really hard time getting into gear from start up. i suspected it was my clutch petal and i adjusted it to the max i really could. Well it worked for a little while but now its acting up again. If anyones got any ideas as to what it may me please let me know thanks
Old Oct 24, 2009 | 06:29 AM
thedru13's Avatar
does it shift ok when the car is off?
Old Oct 24, 2009 | 07:06 AM
BOOSTED04's Avatar
it probably the throughout bearing.
Old Oct 24, 2009 | 07:43 PM
and yes it shifts perfect when the car is off??
Old Oct 24, 2009 | 07:48 PM
LI Pinky's Avatar
Damn Billy I didn;t know you were having this problem again, you didn't mention it at work.
Like the other guy said, yeah it could be your throw out bearing. It's adjusted to the max?
Old Oct 24, 2009 | 08:35 PM
thedru13's Avatar
Yah your tranny is probably ok. Check the TOB like everyone has said.
Old Oct 24, 2009 | 09:38 PM
Force-Fed Performance's Avatar
Make sure the clutch slave is bled if the line was opened. Looking at a bad TOB or something is wrong with the wave ring.
Old Oct 26, 2009 | 10:58 PM
yeah thanks everyone im going to have to look into all these.
Old Oct 27, 2009 | 05:24 AM
Sixth_Vang's Avatar
It's weird but it's a silly trick I learned from my 350z's horrible tranny. If I couldn't get into reverse, I would try to put it in first and then for some reason reverse went in smoothly. Of course, this is just a temporary fix until you can fix what's actually wrong with it.
Old Oct 27, 2009 | 06:39 AM
binh's Avatar
works on evos too
Old Oct 27, 2009 | 08:51 AM
haha that would be a good trick if i could get into first lol. All the gears are hard ot get into. Its like its not ingauging.
Old Oct 27, 2009 | 09:02 AM
06RedRalli's Avatar
clutch slave cylinder...try that before you open up the tranny...
Old Oct 27, 2009 | 12:25 PM
yup thanks man every bit of ideas help lol
Old Oct 27, 2009 | 12:30 PM
06ravenmr's Avatar
im having same problem.. its way easier if i start it up in gear.. if i have to back up i start it in reverse..... let me know what worked...
Old Oct 28, 2009 | 11:58 AM
^ yup i do the same lol. ill let u know
