Urgent Pully help needed!!
Old Oct 25, 2009 | 08:27 AM
AngryEvo8's Avatar
Exclamation Urgent Pully help needed!!
So yesterday I was letting my car warm up, then I heard a loud noise from inside the house. Sounded like someone was letting air out of my tires. So I go outside and pop the hood and notice that the sound was coming from around the powersteering pump area...turns out its the pully below the pump. Im not to sure what this particular pully is used for. But It is a little loose (like I can move it with my hand). Here is a pic attached:
Im concerned about this because Im about 50miles from home and dont want to chance anything....Any help on this issue would be great Thanks
Old Oct 25, 2009 | 08:38 AM
dunk186's Avatar
hey i have the pully brand new i paid 47 dollars plus shippin let me know if you need it cause i dont
Old Oct 25, 2009 | 08:42 AM
AngryEvo8's Avatar
Is it the powersteering tensioner pully? Pics? Pm me Thanks
Bump can I drive home safley?
Old Oct 25, 2009 | 09:02 AM
WHTEVO's Avatar
You'll need a wrench to get it off. Sounds like the bearing inside is worn. Good luck.
Aaron
Old Oct 25, 2009 | 10:43 AM
barneyb's Avatar
There is only one belt which drives all the accessories and the water pump. The pulley in your picture is the tensioner for the belt. The fix is replacement.
I suggest you travel with your cell charged and it anything happens call for a flat bed wrecker.
Old Oct 25, 2009 | 02:28 PM
AngryEvo8's Avatar
Has anyone swaped this before? Or had a similar issue?
