black smoke after WOT
it is not the turbo....log the car and you'll figure out what is happening....black smoke is caused by rich condition....so your question is why am I running rich right after WOT ?....my guess is your o2 sensor, but I would need more info. to be 100%....
Your car is spraying a TON of fuel and then does not lean up quick enough (10:1 AFR after lift off is your problem)....not sure if it is your tune (adjacent cells), fuel injectors, or a bad 02 sensor...
ok...changed the front 02 sensor, code went away from check engine light....so thats fixed...but still smokes.... next im replacing the egr valve.....
my car has 99k miles....
i had 2 codes of the egr valve malfuctioning, and no the vaccum hoses did not pop of it...
ill keep this thread posted when i replace the egr valve tomorrow
ok...changed the egr valve, definitily stopped smoking as much as before, but theirs still some smoke....but very little...their was oil in my old egr valve, what does this mean>??>?
had the same problem using the perrin catch can.....it would only smoke on lift at WOT turned out where the perrin catch can is mounted was right under the front strut tower bar, which had the catch can hose pinched.....once I found this, and straightened the hose out the problem went away....
so check if it isnt piched i would check the hoses and can to make sure they arent clogged...
