Can P0420 error code be caused by air/fuel ratio gauge?
Old Oct 26, 2009 | 02:48 PM
dvd_mi's Avatar
I have a 2005 EVO and recently I installed an Autometer air/fuel ratio gauge which is using stock o2 sensor. Next day I noticed a "SERVICE ENGINE SOON" light. I checked at Autozone and it was a P0420 error code (Catalyst efficiency below threshold- bank 1). I rewired everything again and it was fine for a few weeks until yesterday. The light came on again with the same code. Can it be caused by a/f ratio gauge itself???
Old Oct 27, 2009 | 04:44 AM
dvd_mi's Avatar
Anyone. Please.
Old Oct 27, 2009 | 04:58 AM
rolly1818's Avatar
Registered User
P0420 is the catback sensor not so?
it comes on when u remove it.
can you be a little more clear with your post? are u saying u swapped out ur front O2 for a different sensor???
Old Oct 27, 2009 | 06:30 PM
dvd_mi's Avatar
No. I just installed an Air/Fuel ratio gauge which is using my stock o2 sensor.
Old Oct 27, 2009 | 07:06 PM
rolly1818's Avatar
Registered User
i really dont know what caused it then....if the code is for catbacks then something is up...
did any fuses blow? any connections came loose on the ECU?
does the car drive normal??
Old Oct 28, 2009 | 04:51 PM
dvd_mi's Avatar
No fuses blow and car runs perfectly. I erased the code and it is running fine for 2 days now. I have a 3" buschur racing exhaust with 3" buschur high flow cat converter. It was installed about year ago. and everything was fine. Recently i installed a 3" downpipe and still no problems, until few days ago when i installed that gauge.
Old Oct 28, 2009 | 08:09 PM
rolly1818's Avatar
Registered User
if your sure its not causing an issue then use peripehry bits to disable the code.
Old Oct 28, 2009 | 08:21 PM
bluebanana23's Avatar
just for reference, I have the same code but I already know it's because the rear o2 is out
Old Oct 28, 2009 | 08:27 PM
rolly1818's Avatar
Registered User
same crossed my mind but he kept refering to just the front O2.
Old Oct 28, 2009 | 08:30 PM
D-Mon3y69's Avatar
so your using your second o2 sensor for the gauge? does that mean your sensor isn't reading for the cars ecu anymore? If so that will throw a code. Your car only has that second o2 sensor for your emissions i believe. If you take it so that its not reading for the ecu then you'll throw a code cause your car will think the cat isn't working right.
If its just reading for both then then your high flow cat isn't burning enough for exceptable level in your exhaust or your high flow cat is fowled. There is two threads around here to fix that if that is the case. What you do is drill out a spark plug anti fowler a certain way and it makes the sensor not sense as much exhaust which will keep your cel off. I have a test pipe and i'm using this method to keep mine off.
Old Oct 28, 2009 | 08:43 PM
rolly1818's Avatar
Registered User
^^ good one.... just use bits to remove the code, you dont need to make anything.
Old Oct 29, 2009 | 04:45 AM
dvd_mi's Avatar
What do you mean by "bits"???
Old Oct 29, 2009 | 04:57 AM
rolly1818's Avatar
Registered User
PM me your email addy...
Old Oct 29, 2009 | 06:45 AM
SloRice's Avatar
I can't believe no one has told you this yet!!!
Remove the Autometer Air/Fuel gauge and sell it to some ricer. It does absolutely nothing but look like a flashy, blinky light.
The Autometer and stock O2 sensor are a narrowband setup, so that means they work from 0-1 volts and are useless from a tuning standpoint. The real Air/Fuel gauges (like AEM, Innovate, etc) have their own O2 sensor and are a wideband setup, so that means they work from 0-5 volts and are actually useful from a tuning standpoint.
AGAIN, SELL THE AUTOMETER GAUGE....YOU WASTED YOUR MONEY ON IT.
Old Oct 29, 2009 | 12:23 PM
browningderek's Avatar
the christmas tree strikes again!
