Will Exhaust Silencer Reduce Power?
Old Oct 27, 2009 | 03:33 AM
MR. EVO MR's Avatar
i do have a open dump
if i install the silencer will it reduce power?
will the silencer affect my tune?
Old Oct 27, 2009 | 03:51 AM
4g634life's Avatar
yes and no--- now when you say open dump- do you mean wastegate or open downpipe
-a silencer will not reduce horsepower- if it does, maybe like 2hp!--it only tapers down about 3 incheck of the muffler-----
Old Oct 27, 2009 | 04:05 AM
skyblas's Avatar
it reduce the airflow hence power will be restricted but its not much
Old Oct 27, 2009 | 04:14 AM
Domolution's Avatar
Answer to your question is - YES!!!
If you lose 3-6hp. It's STILL HP lost! So YES!
Old Oct 27, 2009 | 05:21 AM
Sixth_Vang's Avatar
Definitely! These cars don't like silencers.
Old Oct 27, 2009 | 05:50 AM
MR. EVO MR's Avatar
yes emp open dump tube
2-3 hp is not much, no big deal.
what else does a silencer effect besides hp and noise ?
Old Oct 27, 2009 | 06:20 AM
Bobster22388's Avatar
Silencer would also effect the amount of backpressure through your exhast since it has to push it open
Old Oct 27, 2009 | 08:42 AM
tc17's Avatar
i have an apexi active silencer that worked great with my loud jun bl non restricted exhaust(no cat). spring loaded, so it opens up when you're at full throttle. i don't drive my car on the street anymore, so i am selling it if anyone is interested.
Old Oct 27, 2009 | 08:49 AM
DontStopMe's Avatar
I could feel when my silence was in. Seriously felt like a 20hp loss on my old evo. 3" exhuast reduced down to a little over 1" is a huge restriction. Ebay TBE.
Old Oct 27, 2009 | 11:09 AM
kouzman's Avatar
The loss is definitely more than 3-5 whp.
One of the tuner magazines made a test with a silencer. On a Mazda miata the power drop was minimal, I think around 3-4whp but on a turbocharged 200sx with an sr20dett I think thy lost 16whp...
Now can you imagine my fs635 going from a full 3" to 1"? if I go full boost I think I could even damage the turbine blades because of the backpressure!
I bet you I would loose way more than 20whp!!!
Old Oct 27, 2009 | 11:11 AM
chaotichoax's Avatar
the more power your car makes the more power the silencer will rob
on a turbo'd car it's a lot more than 3-5 hp
Old Oct 27, 2009 | 11:24 AM
Ozrally06's Avatar
they just did this test on i think it was import tuner or some other mag and they did it on a turbo 240 sx and it lost i htink it was like 14hp and hit the torque curve sooner than with out the silencer
Old Oct 27, 2009 | 02:05 PM
MR. EVO MR's Avatar
what about my tune?
Old Oct 27, 2009 | 02:14 PM
TxEvo8's Avatar
If you have an O2 dump, then WOT power would not be affected at all.
Old Oct 27, 2009 | 02:24 PM
BoostWhore's Avatar
Your still having exhaust flow come out the exhaust then so its going to reduce your flow by having the silencer.. why not put a quieter muffler on the car - magnaflow race series or add one upstream
