CBRD halfwidth rad, design input..
Old Oct 30, 2009 | 06:46 AM
CBRD's Avatar
the ac condensers are tough in that size... the other issue is we'd have to machine blocks to adapt lines...
im working on solutions for that,
as far as the half width, I would supply a new thermostat housing top with a -16 AN fitting welded onto it, and I could supply that hose also...
the lower could remain stock, and be pulled ENTIRELY over to the driver's side like our time attack car..
keep the thoughts coming,
VW jeff, id love to get one on your car
cb
Old Oct 30, 2009 | 07:25 AM
CBRD's Avatar
ok, i have two options....
one, a single pass 2" thick core, but the tanks will be almost 3".... if that doesnt matter, i can do that..
the other more AWESOME setup would be a double pass, which would put the fittings all the way to the driver's side... meaning, your upper and lower rad hoses would both be all the way at the driver's side end of the radiator.
give me some feedback guys, and ill get one together next week!
cb
Old Oct 30, 2009 | 07:29 AM
btownsoccer22's Avatar
The double pass would be perfect with all AN fittings
Old Oct 30, 2009 | 07:33 AM
crcain's Avatar
cb
CBRD, is it possible that your half width rad with one fan can cool better than a stock radiator with two fans?
CBRD's Avatar
i would offer the rad with a -16 hose from the thermostat housing (which we will supply) to the tank, then the other fitting for the lower hose would be an option depending on what each client wanted...
CB
would you guys want a premounted fan? high cfm? with a nice aluminum shroud?
Old Oct 30, 2009 | 07:35 AM
CBRD's Avatar
doubtful,
i think we can match stock radiator efficiency with one fan.... especially mounted properly using a high density core..
the issue is this, its GOING to cost more than the current honda rads... why? because we will be building it SPECIFICALLY for you guys, and it wont be a rad that 50 companies make...
if it's worth us doing, i WILL build them...
cb
Old Oct 30, 2009 | 07:37 AM
aluminum shroud would be nice, either a pre-mounted fan or a cfm would be fine by me, w/e you think will work the best
CB
Old Oct 30, 2009 | 07:38 AM
crcain's Avatar
doubtful,
cb
My problem is I have VI RS which has a support bar just in front of the radiator, so I can't run a fan on the front of the radiator. This means I can only run one rad fan. I'm in 30c weather, and if I let my car idle in the sun coolant temps rise and rise. I'm thinking a well designed half rad might improve my situation because I don't have half a radiator sitting there getting heatsoaked by my header without a fan.
What price range are we looking at for your half rad?
Old Oct 30, 2009 | 07:56 AM
CBRD's Avatar
I understand,
I can always build you whatever you need, 3/4 width etc...
send me an email with the size you have to work with.
cb
Old Oct 30, 2009 | 10:42 AM
slow/ass/rs's Avatar
go look at ams's core its a honda core you can see where the weld the outlet and move it and i run on a spoolin fab core (thats meant for a honda) and i sit in traffic here in cali all day long no over heating problems at all
Old Oct 30, 2009 | 12:14 PM
vwjeff's Avatar
cb
I have glue and you have a Rad... hmmmmm
I would love to rock 1 of your 1/2 Rads, the standard replacement is an awsome peice
Old Oct 30, 2009 | 12:20 PM
AF-Evo8's Avatar
1. my A/C is long gone.
2. trimming is not a problem
3. stock lower is fine.
4. premounted w/ shroud would be perfect
Old Oct 30, 2009 | 12:21 PM
CBRD_Caleb's Avatar
you're an awesome piece...
wait, wut?
Old Oct 30, 2009 | 01:16 PM
EvoDan2004's Avatar
i could possibly be interested. keep me posted.
whats the weight difference VS the CBRD rad i have now?
Old Oct 31, 2009 | 08:36 AM
CBRD's Avatar
it will be about half the weight lol! its half the rad..
through design work, i think the double pass in the core density we would need to use would offer to much resistance on the system...
so i think single pass may be the way to go..
i will incorporate a heatshield with foil on it, that attaches to the core closest to the turbo to reduce heat soak.
i should have something early this week to run by you guys
cb
