Best Fluids?
Old Oct 28, 2009 | 07:36 PM
grizly3610's Avatar
Best Fluids?
Its time to change my diff and T-case fluids and I was wondering what everybody is using and what they think is the best ? Also is there anything else i should change besides the tranny fluid cuz ive already done that. Car has 33K on it now.
Old Oct 28, 2009 | 08:32 PM
cal1mr's Avatar
I just changed to Amsoil in diff and tc but the car's still on stands so I haven't been able to get an impression.
Old Oct 28, 2009 | 08:37 PM
grizly3610's Avatar
What weights did you use?
Old Oct 28, 2009 | 08:54 PM
charon2123's Avatar
I switched from Diaqueen to AMSoil at my 30k, car seemed to shift a lot better. One of the members on here is an AMSoil rep and I just followed the link to their webpage. You can look up the weights in the fluids sticky, 75w90 is what I think the tranny fluid is. The AMSoil webpage has a lookup tool to tell you the exact type and weight for your car.
You may also want to look into changing out the brake fluid. I just helped my buddy change his and it was pretty nasty looking; hadn't been changed in 50k, since new.
Old Oct 28, 2009 | 09:42 PM
cal1mr's Avatar
The stuff for the tc and diff is called SVG, contact apagan01 if that's what you want. Delivery is quick. You should search a little more as well.
Old Oct 28, 2009 | 10:00 PM
06ravenmr's Avatar
diaqueen 75 -85 for t case and redline for trans 1 quart redline lightweight shockproof and 2 quart mt90. ur mr will be verry happy
Old Oct 28, 2009 | 10:17 PM
ch53avitech's Avatar
Hmm... the search function must be out of order. Thousands of posts on this subject. A quick search will yield you the results your looking for.
Can't go wrong with AMSoil, OEM fluids, redline. I personally use the OEM fluids.
Again, this post has been covered numerous times. Search first.
Old Oct 28, 2009 | 10:19 PM
ChrisBond1's Avatar
i have amsoil and i don't really notice a difference. all i know is that i can run the fluids longer = saving me money..
Old Oct 29, 2009 | 04:11 AM
apagan01's Avatar
Any questions let me know we can help.
