Injector Resistor Evo VIII 2003
Old Oct 30, 2009 | 08:03 AM
Sumarez's Avatar
Has anyone ever heard of a fuel injector resistor in the Evo V111? It's a stock part came with the car. I need one and the dealers in ma have never heard of it. Anyone know where i can get one? Thanks Sumarez.
Old Oct 30, 2009 | 08:37 AM
MR Turco's Avatar
How do you know you need one? I have also never heard of it.
Old Oct 30, 2009 | 08:54 AM
antilag_200's Avatar
are you talking about the injector resistor box ? if so it is located right by the abs unit.. If it is faulty you will get inconsistant voltage values at the plug end that goes to the injector.
I know this, because my car ran on 3 cylinders, before we figured out that the resistor box was bad..
hope that helps
Old Oct 30, 2009 | 09:14 AM
JohnBradley's Avatar
^^^ what he said. Its not common for them to go bad, but its the same part from 1990 to present on turbo Mitsus.
Old Oct 30, 2009 | 10:54 AM
Gary@MellonRacing's Avatar
what voltage do the plugs need to have ?? i tried reading mines and they were 13.9 volts
i have an evo 6 , we r having problems , it dosent want to turn on , beacuse we r not getting the injectors to spit the fuel
1. we are not 180 degrees off timming
2. we checked all sensor are getting signal
3. we have presure on fuel rail , cause we can see it on a guage we have
4. we have spark
5. we have new fuel pump
6.but the injectors have voltage , but they just dont spit FUEL
Old Oct 30, 2009 | 11:31 AM
how are u seeing 13.9 volts if the car won't start ?
try doing this.. turn the car off.... on one prong of the injector hook it up to 12volt source and the other side attach some clips so that you can ground it out. then listen to see if the injector clicks... if it does then the injectors are working just fine...
Sounds like a bad crank angle/cam angle sensor, if it is not starting...
Old Oct 30, 2009 | 11:40 AM
crewdawg130's Avatar
I got 3 If you need one. pm me
Old Oct 30, 2009 | 06:08 PM
ill give that a a try , if the cam angle sensor is damaged , i t would fuel the injectors ??
roni4g63
Dec 22, 2016 04:55 PM
Raceghost
For Sale - Part Outs
Aug 22, 2016 09:32 AM
Dave99gst
Mar 28, 2016 05:55 AM
Logie888
Mar 12, 2015 11:41 AM
yweleung
13
Jun 20, 2012 05:45 AM
