A lag monster is spawned! (cam timing)
Old Nov 1, 2009 | 08:06 PM
03whitegsr's Avatar
Huh?
The ignition timing comes from the crank shaft position sensor. Isn't the cam position sensor only used to determine which cylinder is supposed to fire and what injector to fire when in sequential mode?
Old Nov 1, 2009 | 08:22 PM
JohnBradley's Avatar
Hmmm...I will have to doublecheck, I thought it referenced both. I know the older DSMs had both in the CAS, the 95-96 was in the intake cam gear ,and the 97 up was more like ours. I only mentioned that because I just did an Evo/2G ECU swap and base timing was affected by the CAS even though I was only using cam position from the CAS.
I could be wrong though. I will withhold comment until I have done further testing.
Old Nov 2, 2009 | 12:41 AM
kjewer1's Avatar
On a 2g or an EVO, cam timing does not affect ignition timing. On a 1g with the crank sensor also on the cam, it does. I made this mistake on the dyno with my RWD. Pulled the intake cam back 4 degrees, which was an 8 degree timing retard. Oops. No affect on EVOs, which is what lulled me into complacency and led to this boneheaded mistake.
Old Nov 2, 2009 | 12:59 AM
alan678's Avatar
+2/0 on the Cosworth M2's on my Evo 8 had my 35R full spool/peak tq @ 4200rpms...
Old Nov 2, 2009 | 01:22 AM
RSMike's Avatar
thanks for all your replies.
Synapse BOV in.
Cam gears here, i'll install them tomorrow afternoon (ran out of time tonight).
Cheers, Mike
Old Nov 3, 2009 | 11:37 AM
RSMike's Avatar
Is this on the dyno? or street logging? 3rd gear, 5th gear?
Old Nov 12, 2014 | 12:01 PM
StockSpyder's Avatar
Hey guys, saw a broken link here and wanted to share the right link.
http://my.prostreetonline.com/2013/0...g63-cam-gears/
Thanks everyone.
Old Nov 14, 2014 | 04:21 PM
EvoTurboTurk's Avatar
Does the 35R turbo leak?
chaotichoax
Apr 12, 2020 11:55 PM
tscompusa
Feb 27, 2015 05:45 PM
tscompusa
Feb 24, 2015 01:20 PM
JamaicanEvo
94
Dec 24, 2012 09:27 AM
David Buschur
Jul 23, 2011 07:19 AM
