Carrillo vs Manley
Old Nov 2, 2009 | 08:46 PM
Tonba's Avatar
I went with carrillo. They are the bees-knees here...
Old Nov 2, 2009 | 11:11 PM
AWD Motorsports's Avatar
Originally Posted by Ted B
Are you certain both are the same price? If so, it's a no brainer.
Manley's H-beam rods are forged in China, and typically sells for around $350 or so per set.
Carrillo's H-beam rod for the EVO is U.S. made and typically sells for around $1000 per set.
If you can choose either for the same price, which would you prefer? The answer should be easy. To be honest with you, I wouldn't even consider a Chinese-made rod, at any price, but that's just me.
Well Im pretty sure he said 300m which are not the eagle look alikes..
I would choose carillo because without even knowing ill bet they are lighter for sure and just as strong.. easier for us to give advice if we know your goals with the car and HP / RPM etc..
Mike
Old Nov 3, 2009 | 07:56 PM
Teal2nnr's Avatar
Ya i should have been more descriptive. I'm building the motor for 600+ WHP 94 octane ( i can't get E85). Engine is being matched to a 6262 ...etc. But ya i think i'm going to go with the Carillos they seem to have an excellent rep.
Old Nov 8, 2009 | 06:34 PM
mandy1's Avatar
i went with map ultimate billet rods,they are heavy 652g,but love the idea of running early 4g63 wider bearings
Old Nov 8, 2009 | 06:38 PM
JC evo1's Avatar
whats the size difference between 7bolt and 6 bolt bearings ?
Old Nov 8, 2009 | 06:40 PM
Gordian79's Avatar
Rods are as strong as the crank they rotate on.
Old Nov 9, 2009 | 02:07 PM
big block dsm's Avatar
manley...i have built alot of motors and i have never had a problem with manley rods in anything i have ever build dom/import
Old Nov 25, 2009 | 11:23 AM
konstantinosIX's Avatar
I am in the same quest today.
Which of these two should I buy?
Manley 300m or Carrillo???
Specs of my Evo IX????
Engine mods:
2.0lt ,
K1 crank,
Rods ????????? (I will use ARP custom age 625+ rod bolts and I'll get rid the OEM... I have them anyway)
JE BR specs pistons,
Cosworth head,
Tomei 280 cams,
4 channel Sparktech COP,
Motec M800 ECU,
PT6765 turbo kit,
HKS Kansai manifold with Q45 TB,
HKS 4" IC
ACL Race series bearings
etc,etc.
Shep trans 5 speed
Shep transfer w/ LSD,
Shep RS from EvoIX diff w/ cusco LSD,
DSS axles,
AMS push style triple cerametallic clutch kit.
Old Nov 25, 2009 | 12:08 PM
Carrillo 567 gram. 1000+ whp
Manley 685 gram. 1300+ whp
Cosworth 548 gram. 1000+ whp
Cosworth and Carrillo are straight H beal.
Manley is I beam.
Old Nov 25, 2009 | 02:16 PM
CO_VR4's Avatar
Originally Posted by N33d4sp33d
Go with Groden aluminum rods...high HP rods
You'd be well advised to do a little more reading on aluminium rods in general, and Groden 4g63 rods in specific. Take a look at the English Racing photos of a Groden rod that failed at the threads, then come back and discuss...
Old Nov 25, 2009 | 02:23 PM
Ted B's Avatar
Good info on the rods, but those power figures don't mean much. A 2000whp 5.0L V8 is approximately the same specific output as a 800whp 2.0L 4-cyl.
Old Nov 25, 2009 | 02:53 PM
These power advertisements is for the Evo rod kits.
So what would you choose?
Carrillo or Cos?
Old Nov 25, 2009 | 03:08 PM
Ted B's Avatar
I know of a recent instance whereby a Cosworth EVO rod snapped in half unexpectedly, so I find no reason to consider those. Actually, I'm not sure that I would consider any very lightweight H-beam rod for a high hp application where someone is going to take it out and beat it to the ragged edge with >400+whp/L, but that's just me. If I had to choose between Cosworth and Carrillo, I definitely choose Carrillo. I know who makes Carrillo's rods. I don't know who makes Cosworth's rods.
Old Nov 25, 2009 | 04:10 PM
Erik@MIL.SPEC's Avatar
From what I understand, you should also consider the fact that many "American" rods don't use North American steel. They use less expensive material from South American foundries. And 548 grams seems light for a rod that's supposed to handle 1000whp. That's a commentary on the weight, not on the company. Just my 2¢.
Old Nov 25, 2009 | 09:56 PM
dambikeracer's Avatar
Manley's = Heavy
http://www.manleyperformance.com/sc/...g63_rods.shtml
carrillo = light weight steel
http://www.carrilloind.com/LinkClick...vg%3d&tabid=60
GRP = Light weight Alum
http://www.grpconrods.com/
