Cant get o2 sensor out of o2 housing
Old Nov 1, 2009 | 04:40 PM
ilikeppie's Avatar
Any advice i have tried wd40 and heating it up, the m effer is rounded off so i cant get much of a hold on it. if i do buy a new one would it be ok to just get the universal sensor and put my connector on it? thanks
Old Nov 1, 2009 | 04:47 PM
suekie's Avatar
take the 02 housing, put it in a vice and take out the o2 with some locking pliers (vice grips)!
As far as using the universal one, i dont know...
Old Nov 1, 2009 | 04:51 PM
ilikeppie's Avatar
good thought idk if the vice grips will hold though
Old Nov 1, 2009 | 04:52 PM
ak47po's Avatar
Old Nov 1, 2009 | 05:32 PM
Ev0ikon's Avatar
Talking
Originally Posted by ak47po
Nice! But 's no good after the plug is rounded off.
Use a really big vise-grip.
Old Nov 1, 2009 | 05:39 PM
GEJEN's Avatar
drive around for a while and then use pb blaster.
Old Nov 1, 2009 | 05:43 PM
MR Turco's Avatar
Vice grips and heat, lots of heat.
Old Nov 1, 2009 | 06:39 PM
Babs's Avatar
Wow...exactly what I went through last night. Used an O2 socket, rounded it off. Got a torch, heated it up, went at it with vice grips and completely shredded the hex.
That sensor is still in the stock housing. I'm currently driving around without a primary for a day or two with my Megan because I had to order a new sensor. Keeping it under 3k and zero problems.
Old Nov 1, 2009 | 09:18 PM
JohnDoe1984's Avatar
Kroil.
It's simply the best rusted part loosening agent there is.
http://www.gamaliel.com/cart/product.php?productid=6478
Old Nov 1, 2009 | 09:22 PM
MR BURTON69's Avatar
Mine was tough to get out too, we just sprayed it down with pb blaster let it soak heated it up and gave it hell with a wrench and it came out.
06ravenmr's Avatar
y u taking the sensor off. ive had problems with this as well. if u can leave it on then just leave it on...heat will work but most likely the sensors threads will strip out
Old Nov 1, 2009 | 09:25 PM
Evo_Jay's Avatar
Take it out, put it in a vice and use a that appropriate big wrench (I dont remember which one off the top, but its 22 or 23mm, I think)
The wrench I use is a regular wrench, just quite big since its such a big size and it give you way enough torque to get out the most stubborn O2 sensor.
Old Nov 2, 2009 | 03:38 AM
MR Turco's Avatar
you aren't using enough heat.
Old Nov 2, 2009 | 05:53 AM
ilikeppie's Avatar
I think i am going to just have to buy a new one at this point it is pretty shredded up and i dont think i have the means to heat it up enough i had to soldering torches on it for about five minuted or better and didnt do a thing as for why i need to take it out is because i am swaping the o2 housing to a EPM O2 dump
Old Nov 2, 2009 | 06:39 AM
I hope ur epm doesnt have fitment issues like my friend. His burnt a hole thru his lower intercooler hose. IMO Map 02 is the route to go, no fitment issues. I almost went with the EPM but was talked out of it, just my .02 cents tho.
