My Porting Job!!
Old Nov 5, 2009 | 05:05 PM
erald01's Avatar
My Porting Job!!
I got a 10.5 hotside and i thought i would ported it out so i can squeze every little power out of it, here is some pics let me know what you guys think and where do i need to do more porting...thanx
Old Nov 5, 2009 | 05:06 PM
Malik_EvoIX's Avatar
Nice porting
Old Nov 5, 2009 | 05:14 PM
erald01's Avatar
thanx..i thought so too for my second time, and my first time was 4yrs ago..
Old Nov 5, 2009 | 05:15 PM
MR Turco's Avatar
Looks like you screwed up the gasket surface on the twin scroll portion of the manifold.
Old Nov 5, 2009 | 05:31 PM
erald01's Avatar
yeah i noticed that a bit but do you think it will make a difference?
Old Nov 5, 2009 | 05:40 PM
sparky's Avatar
WTF bit did you use to do the porting anyway? You f'd/up the outer edges of the entrance to the turbine inlet area. That outer, lead-in edge should always be left for last.
Old Nov 5, 2009 | 05:58 PM
adWRXi's Avatar
you have patience my friend.
Old Nov 5, 2009 | 06:01 PM
sparky's Avatar
It just looks like he did it with a rat tail file.
Old Nov 5, 2009 | 07:41 PM
erald01's Avatar
yeah got a little exciting there with the inlet edge, and i did do that last BUT i dont think it will make a difference anyways beause that part will have the gasket on top.
Old Nov 5, 2009 | 07:48 PM
JDMevoBOOST's Avatar
I just hope the gasket seals man. That gasket surface should always be left flat. I think you should have taken some harder looks at professional port jobs and figure out is beneficial to remove material. You might have done more harm than good on this.
Old Nov 5, 2009 | 07:51 PM
TTP Engineering's Avatar
its too rounded at the twinscroll divider. It will probably leak
Old Nov 5, 2009 | 07:53 PM
newimportowner's Avatar
Looks a little iffy in the middle.
Old Nov 5, 2009 | 07:56 PM
buchnerj's Avatar
I don't think that gasket will seat properly. Hopefully it does, but it would be a shame after all that work if it leaked and you had to swap it all out... sorry to see that, but I am hoping it works for you!
Old Nov 5, 2009 | 08:39 PM
Steve93Talon's Avatar
I'd throw that thing out.
Old Nov 5, 2009 | 09:33 PM
Kracka's Avatar
Sorry man, but you definitely did more harm than good. Your gasket isn't going to seal and you're going to have a lot of additional turbulence. I wouldn't bother putting that on your car and just pick up another core to start fresh on and learn from your past mistakes.
