HELP with oil leak!
Old Nov 5, 2009 | 06:30 PM
john blaze's Avatar
HELP with oil leak!
i been trying to track down a really bad oil leak on my car. i found that its leaking from the actual engine block around where the stock o2 housing bracket is located. the oil only sprays out of this hole when i raise the throttle. it seems like theres suppose to be some kind of plug that covers this hole, but i looked really carefully and dont seem so see any threads in the hole(from what i can actually see). i circled around where this hole is on my engine block, hopefully someone can give me some sort of answer. thanks in advance.
Old Nov 5, 2009 | 07:14 PM
Hi Im Vinh's Avatar
after installing my aftermarket o2 housing my friend forgot to place the oem bolt that once held the L-bracket for the oem o2 back onto the block . That was the cause of my leak , so all I had to do was put that bolt back in and no more oil leak .
Old Nov 5, 2009 | 07:50 PM
john blaze's Avatar
thank you so much my man. i will put the bolt back on tomroow and let you know how it goes.
