What goes here?!?
Old Nov 6, 2009 | 10:53 AM
Kapoosh1's Avatar
What goes here?!?
So, i've been having problems with the car going lean. I had it de/retuned and it seems fine now. Lately i've been crazy bad gas mileage so I decided to look under the hood again and see if anythings obviously wrong.
I might be going crazy, but I don't think these used to be open before. If someone has a picture or can just tell me what goes in these 2 spots it would be greatly appreciated.
The two empty places are circled in red
Old Nov 6, 2009 | 11:26 AM
ROGERV's Avatar
That's your fuel pressure regulator...you need to connect a line going to those 2 nipples.
I will see if I can find a picture of the lines on the serv. man.
Old Nov 6, 2009 | 11:27 AM
SBR INC's Avatar
that's correct. you need a vac line of some sort to get those connected. Should help your issue. Get some zip ties on it to hold it together, well.
06ravenmr's Avatar
just put a line connecting the two..
Old Nov 6, 2009 | 11:31 AM
Kracka's Avatar
Possibly your FPR solenoid is just bypassed. Does the vacuum hose coming from the FPR connect directly to the intake manifold?
Old Nov 6, 2009 | 01:07 PM
Kapoosh1's Avatar
I don't know if you can tell from that picture if it is or isnt.....
Old Nov 6, 2009 | 01:15 PM
Kapoosh1's Avatar
So I guess it probably is bypassed. I think the people that were trying to diagnose the going lean issue might have bypassed to see if that was the problem.
Does it matter if it's bypassed? Should I still connect the two nipples?
Old Nov 6, 2009 | 02:27 PM
Teal2nnr's Avatar
Connect em, why not give it a shot
Old Nov 6, 2009 | 03:53 PM
Kracka's Avatar
You're fine bypassing the solenoid. Make sure the lines are good and don't have any leaks (check that boost gauge hose too). All the solenoid does is add fuel pressure for cold starts but if you have an aftermarket fuel pump there is no point. I have mine (along with most other emissions systems) removed and never had an issue even during the cold Minnesota winter last year.
Old Nov 6, 2009 | 03:57 PM
Kapoosh1's Avatar
Allright, i'm going to check tommorrow. I usually get about 250 a tank, my last tank only lasted 175 miles!
Old Nov 6, 2009 | 04:01 PM
Kracka's Avatar
That would mean you're running on the rich side. Have you installed an aftermarket fuel pump w/o getting a retune or tested for boost leaks?
Kapoosh1
Jul 18, 2011 06:54 AM
Kapoosh1
For Sale - Wheels / Tires
Jun 18, 2010 11:43 PM
Kapoosh1
Apr 13, 2010 03:09 PM
Kapoosh1
Apr 24, 2009 09:18 PM
Kapoosh1
Jan 7, 2009 09:05 PM
