Car Breaks up doing 3rd Gear Pulls Only? Help
Old Nov 9, 2009 | 07:58 PM
Evokid03's Avatar
Hey guys, recently my car was tuned and we came to a issue where my car will break up extremely bad when i do a 3rd gear pull..The boost spikes to about 34psi.
But if i do a full run 1-4th, the car runs like a champ (No break up)
My current setup
Evo 9 turbo (Ported)
Stock Exhaust Manifold (Ported)
Stock Intake manifold (ported by buschur)
boomba 65mm tb
Br Uicp
tial bov
Ams Intake pipe
perrin filter
Strictly Modified Fuel rail
1050cc fic Injectors
Ams knockoff Fmic
Ams licp
megan o2 housing
Invidia 3" exhaust (no cats/no res)
fp4r cams
arp headstuds
NGK bpr7es .022 gap
e70 (winter blend) tune holding 28 psi
current best time 11.30 on first pass at the track
Can anyone help us out??
Old Nov 9, 2009 | 08:10 PM
BLKCarbonEVO's Avatar
First thing I would think would be surge, but shouldn't be a problem on stock turbo... So not to sure. Have you logged the car in a 3rd gear pull?
Mikey
Old Nov 9, 2009 | 08:32 PM
Evokid03's Avatar
Yes the car was logged of course, but from what i understood.. The car would not knock consistantly.. If he tuned a certain area of knock , after correction another area would appear knock.
Ill have Kunal Pitch in this thread to give it more detail
Old Nov 9, 2009 | 08:53 PM
My car did the same thing when I blew my turbo. The exact same thing. I would check your shaft play. I cracked my divider and splintered my shaft pretty bad... 1st-4th no problem but if I loaded up in 3rd or 4th it would knock throughout the powerband in odd places and couldn't fix it. That's how we realized the turbo was shot, bad!
Old Nov 9, 2009 | 08:54 PM
Evokid03's Avatar
fml, another bad turbo lol
Il check it out 2moro
Old Nov 9, 2009 | 08:58 PM
EvoRob22's Avatar
Sounds like your best bet. Although I know thats not what you wanted to hear. Good luck.
Old Nov 9, 2009 | 09:12 PM
If it is blown then just get a Red. But Robert won't be able to do it as an upgrade though, he would just have to look at it first and see... Sorry for your bad luck if that's what it is but it happens to the best of us.
edit* have you had a blown turbo before.
Mikey
Old Nov 9, 2009 | 09:41 PM
Evokid03's Avatar
yes lol, maxing out my stock turbos isnt to healty
Old Nov 9, 2009 | 10:13 PM
ya I put down 430 on pump+meth before mine took a ****. Just upgrade to a red. It is an awesome turbo and easy 500hp and fairly safe!
Old Nov 9, 2009 | 10:28 PM
R/TErnie's Avatar
+1 for the Red. doo eet! You can buy mine and I'll buy a black.
Old Nov 9, 2009 | 10:33 PM
Evokid03's Avatar
lol hahaha, sorry but if its the turbo.. Il be ordering a black no matter the wait
i got a evo 8 turbo layin around
Black = you still wont be happy... However I think with some of your "magic" it might be shocking what that turbo will do
Mikey
Old Nov 9, 2009 | 10:38 PM
Then next you will be blowing your motor On stock motor you would be limited to pump/30psi. I think pushing the black much further would send your rod through the block bud.
Mikey
Old Nov 9, 2009 | 10:47 PM
R/TErnie's Avatar
Mike... you should just buy a 42R and get it over with.
Old Nov 9, 2009 | 10:48 PM
Evokid03's Avatar
unless the red is Dirt......
