manual transmission will not shift
Old Nov 11, 2009 | 05:37 PM
TGC_QS's Avatar
hey guys
i was on the highway on 4 gear , tried to shift to fifth but didnt work . it didnt rattle and scrinched like when u miss the gear or dont clutch enough
the stick shift was just blocking and wouldnt go to the fifth gear position. i got at a friends house, turned the car off , tried to shift all the gears and the 5 and reverse gear wouldnt go in
i force it a bit and it went into fifth gear . but i couldnt get it out anymore , i started the car, while still holding the clutch, gave it a little gas and it went in neutral
but now it wont go in ANY gear at all , it feels like something is blocking the shifter or something.
is it possible its the shifter cable ?
ive been runnning the car for a week , and today i took it out for an hours drive .
everything was working perfectly ( expect the fifth wouldnt go in ) until i turned the car off, put it into fifth and back to neutral .
the tranny im using has been reinforce near the rear engine mount , directly where the shifter cables were supposed to bolt , so they ended up an inch higher that they were supposed to be
anyway could the tranny be done for
im running evo engine with k & n typhoon kit , turbosmart dual port , 3 inch straight exhaust , with tubular turbo manny ,with bully 6 puck clutch , eclipse 2001 manual tranny
is it too much and it blew the tranny ?
or maybe im just low on oil ( i think it happened to sethest once ) i know theres the cap with the gasket on the bottom of the 01 eclipse tranny , is there a refill plug somewhere ?
im starting a new job in 2 days , just my luck i got no car
im gonna go tomorrow morning with my tools and il check the cables out , il try to shift the tranny manually with the cables unplugged .
i really really hope i didnt break it while putting it into fifth
plz help
