clutch pedal dropping to the floor after EVO sits overnight???
Old Nov 15, 2009 | 08:21 PM
E85evo8's Avatar
I've noticed recently that after I leave my evo to sit for a long period of time...i.e. overnight that the next morning the clutch pedal drops almost to the floor and sometime it won't let me engage any gear until I manually pull the pedal up/to the top....then it works fine the whole day!!
I called up Quartermaster clutch to see what they thought as that is the clutch i'm running now...they seem to think it might be my clutch master cylinder, but I'm posting up to see if anyone else has had or has this problem as well?? Thanks!!
Old Nov 15, 2009 | 08:37 PM
evofabulous's Avatar
check your fluid level, check your slave cylinder for leaks. those may be some cheaper things that could be the problem too.
Old Nov 15, 2009 | 08:38 PM
sorry for the double post but try to bleed your clutch too.
Old Nov 16, 2009 | 02:47 AM
Ekoy's Avatar
+1 bleed your slave cylinder, You might have obtained some air in the system or your low of brake fluid in the master cylinder.
Your clutch is fine.
Old Nov 16, 2009 | 05:37 AM
Blue Evo Racer's Avatar
yeah the exact same thing happenned to me two weeks ago my clutch slave was leaking had to get it replaced...but 1+^ check if theres any air bubbles in the line first but the leak will be the most notable thing if you know where the slave is...$200 to get it replaced by mitsu over here in north jersey
Old Nov 16, 2009 | 05:46 AM
cicciaro's Avatar
i agree on the slave cylinder
Old Nov 16, 2009 | 07:09 AM
thedru13's Avatar
Slave is super easy to replace. If its bad. Part is around 50 bucks. If you need one PM me I haev an extra.
Old Nov 16, 2009 | 07:19 AM
E85evo8's Avatar
I have a hydraulic TOB and no longer have a slave cylinder. This clutch is only 2 or 3 weeks old so I know it's not the clutch itself as it has to do with the hydraulics. I will try and bleed it again but we did do a thorough initial bleed after install
Old Nov 19, 2009 | 07:11 PM
brokenRS's Avatar
Mine is stuck to the ground, wont even let me go in gear. I have heard of TOB popping out on the QM. Did you get this problem fixed yet?
Old Nov 20, 2009 | 05:44 AM
E85evo8's Avatar
I haven't investigated further into this as the clutch works fine after I pull the pedal upwith my foot. I haven't heard anything about the tob popping out with the QM hydraulic tob
Old Nov 20, 2009 | 09:41 AM
EvoRob22's Avatar
The two components that would cause this would either be your Slave Cylinder or you Master Cylinder. Bleed the system first. If you get air out of the system note that. If the clutch does it again after you bleed the system try bleeding again. If air comes out again you have a leak in either the Master Cylinder of Slave Cylinder. Slave Cylinder would be the likely cause but Master Cylinder could do the same thing. Good luck.
Old Nov 20, 2009 | 10:29 AM
E85evo8's Avatar
Thx for the help! I will bleed the system again and see what happens next week. If the problem gets worse then I will be replacing the master cylinder.
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
DuBBzEvo27
Sep 4, 2014 08:54 AM
jeffgolik1985
Lancer Troubleshooting
Feb 19, 2014 03:32 PM
cmross13
May 30, 2013 07:43 AM
MDEVO
30
May 16, 2005 04:56 PM
