Boost Drop after Turbo Back exhaust
I just installed a B&B Turboback exhaust, but kept the factory cat on (for now). I did not have a single problem with fitment, or the gaskets they used. I love the look, and the sound is exactly how I wanted it, not to loud but noticeable at WOT.
My question is: Is it normal for the car to actually lose a bit of boost? I was seeing almost 19 at redline stock, and now its tapering to about 1.2 bar. The car does feel faster! Do i really need to reset the ECU per instructions?
TIA..
TIA..
Does disconnecting the battery accomplish this?
When I installed my Vishnu TB I noticed a bit of a boost drop for the first day or so also. Once the ECU optimized itself again boost would peak 1 or 2 PSI higher than stock and seemed like it would not taper as bad. I did replace to 02 housing too, so that may have something to do with it.
Resetting the ecu will not effect the boost - its a open loop system
I suggest a MBC or EBC and / or a boost controlling reflash like our stage rev - you will not get higher boost but it will stay steady to red line instead of falling off with our reflash
