My Kelford 272 install
Old Nov 17, 2009 | 05:17 PM
4RETECH's Avatar
Hi guys , just wanted to let you know I installed the kelford 272's last Saturday.
The info on this site is great. Install, video,etc.
I wanted you to also know that due to time, I had to jam it all back together.
I did not bleed the lifters......
What I did instead was to slowly rotate the engine over 5 times. Really just to check timing.
I figure if my lifters are going to make noise,I'll change them. They never did..
I just wanted you guys to know how I did it, Maybe I just got lucky??
Old Nov 17, 2009 | 05:21 PM
EvolNinja's Avatar
So you start the motor up and it runs normal? I highly recommend bleeding the lifters rather than buying whole new sets. Did you by chance replace your springs and retainers due to the Kelford Cams?
Old Nov 17, 2009 | 05:25 PM
sphinxof2006's Avatar
dont bleed the lifters BE A MAN
Old Nov 17, 2009 | 06:32 PM
bostonhatcher's Avatar
You really only have to bleed the lifters if the base circle of the new set of cams is the EXACT same as the previous set. I wouldn't risk it. Bleed them. Takes an extra 30 minutes. If not they'll be auto adjusted to the previous set and will hang open a tad when they're supposed to be closed.
Old Nov 17, 2009 | 08:21 PM
4RETECH's Avatar
Runs normal, just have to flash for idle.
Spring and retainers, I'm saving up for...
I'm an older guy who doesn't go past 6,000RPM much....
Old Nov 17, 2009 | 08:34 PM
Evo_Jay's Avatar
If your engine has 190K miles and is running stock spring & retainer on the Kelford, I would maybe be a lil scared, regardless of not going above 6Krpm that much.
If you didnt wanna change springs and retainers, you should have went with a HKS 272s or280s or something.
