crankshaft
Old Nov 19, 2009 | 04:25 AM
mandy1's Avatar
crankshaft
need a new crankshaft and want your opinion about stay with a genuine one or a eagle 88mm.dont want a stroker cause i have brand new MAP ultimate billet rods.i can get the genuine in $825 with tax, eagle is cheaper than this.
Old Nov 19, 2009 | 05:02 AM
awd2gen's Avatar
Go with OEM. The OEM crank can take whatever you can throw at it. Only other thing I would suggest if you really don't want to go OEM would be a K1 crank. That will run you about $1600 though
Old Nov 19, 2009 | 03:51 PM
20gmr's Avatar
find a good used crank. There is one right now in the for sale "engine drivetrain and power" for 380ish shipped I believe.......WAMMY
Old Nov 19, 2009 | 04:03 PM
AWD Motorsports's Avatar
Go with a stock crank.. if Eagle balances the crank anything like their rods its garbage..
Mike
Old Nov 19, 2009 | 04:08 PM
bostonhatcher's Avatar
Are the Evo cranks nitrated like the 1g 6 bolt cranks? If so, how deep does the nitrating go?
Old Nov 19, 2009 | 04:12 PM
Ted B's Avatar
EVO cranks are induction hardened, not nitrided.
Old Nov 19, 2009 | 05:09 PM
EvoRob22's Avatar
Go with OEM like everyone here is saying. Why do you need a crank in the first place?
Old Nov 20, 2009 | 03:34 AM
Evo8Emperor's Avatar
stroker or 2.0 your still using the same piston and rods. All thing that is needed is to notch the block where the crank hits it.
As a sidenote I have a used oem crank for sale if interested.
Old Nov 20, 2009 | 04:03 AM
mandy1's Avatar
mine cracks in #4 rod journal.
Old Nov 20, 2009 | 04:08 AM
mandy1's Avatar
i take a look in that section but cant find nothing,any link.
Old Nov 20, 2009 | 09:50 AM
EvoRob22's Avatar
https://www.evolutionm.net/forums/sa...g-20k-ppi.html
350$
Old Nov 23, 2009 | 08:53 PM
Tonba's Avatar
Go a 100mm 4G64 crank and grab yourself some 2.3L stroker pistons. You will love the torque!
Old Nov 23, 2009 | 09:04 PM
EvoRob22's Avatar
Old Nov 23, 2009 | 10:19 PM
cssaddictm4's Avatar
Mandy, any luck on that local crank in PR?
