fp black on pump vs fp red on pump
Old Nov 23, 2009 | 03:22 PM
stryfetew's Avatar
Im looking for 425-475 on pump from either the red or black.. Race gas kind of hard to come across.
Old Nov 23, 2009 | 03:25 PM
BLKCarbonEVO's Avatar
^ A black will make over 500hp on pump. It will on my car and my friend and I will be testing a few things over the next month. It may be the first of the year because I'm leaving the country soon...
Mikey
Old Nov 23, 2009 | 04:58 PM
JohnBradley's Avatar
We'll have a Red back to back on our dyno right after T-day. It will baseline monday night, get swapped tues morning and be back on the dyno by mid afternoon if things follow the plan.
Old Nov 23, 2009 | 05:08 PM
Gary@MellonRacing's Avatar
great ,
^ Dan's car?
Old Nov 23, 2009 | 05:43 PM
Originally Posted by BLKCarbonEVO
^ Dan's car?
Check
Old Nov 23, 2009 | 05:45 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
My sponser is trying to convince me to swap out my Red for a Black but he told me with my setup it will make about 500-520 easy and that's on stock block and head
Old Nov 23, 2009 | 06:13 PM
stryfetew's Avatar
Guess the black it is for me then! Just to get the injectors and twin disk and bolt that beeotch on..
Old Nov 24, 2009 | 09:05 PM
crcain's Avatar
^ Well I agree, but I think the Black will stand for itself here shortly. The Black is/will be a sick *** turbo on the right setups. Having a larger compressor wheel will def help out. Most of us are able to push the Red to the limits of the compressor wheel. The Black is designed to flow at a higher rate and operate more efficient. Robert did a great job at that!
Bottom line for Black on pump...
MAKE EVERYTHING FLOW BETTER AND IT WILL OUT PERFORM THE RED! Certain modifications will make the compressor wheel come to life
Mikey
I'm sorry but I have to ask... it seems you are kind of new to this board I think... and it also seems from my limited perspective that you have made about 10 million posts about the FP Black. Can you just sum up for me the essence of what it is you like to say about the black in a sentence or two? Sort of the cliff notes?
I don't quite understand how a turbo can have so much said about it. Especially without things like compressor maps, a/r, trim, turbine and compressor sizes, flow numbers, etc...
The Black vs Red is pretty simple stuff... the Black is bigger, therefore it can run higher boost levels more efficiently. Boost for boost the Black will not make much more than a Red. If you won't exceed the boost level a Red is efficient at, than a Black is probably a bad choice. End of story.
Sorry for the rant but for christ sake, it's a turbo a bit bigger than the Red. WTF do we need a thousand threads about it for?
Old Nov 24, 2009 | 09:10 PM
Gordian79's Avatar
why is this even a thread?Black will obviously spool slower (not by much) and make more power then a red.More air=more power
Old Nov 24, 2009 | 09:24 PM
^^^not 100% true , ive seen guys on gt35s run 12s
Old Nov 24, 2009 | 10:04 PM
cij911's Avatar
Amen....Now tell me about the Pink....
Old Nov 25, 2009 | 12:23 AM
F0RSAKEN's Avatar
When does the magenta come out?
Old Nov 25, 2009 | 02:54 AM
Evo_Jay's Avatar
Originally Posted by stryfetew
We was tricked..
+1
And Ban the OP
Old Nov 25, 2009 | 03:13 AM
Evo_Jay's Avatar
Only because of ****ty tunes and/or ****ty drivers.
