fp black on pump vs fp red on pump
Old Nov 23, 2009 | 07:14 AM
Gary@MellonRacing's Avatar
Question fp black on pump vs fp red on pump
has anyone swapped the red for the black , and has tuned on pump 93 octane , if u have please share info on how the fp black is on pump
spool , lag , hp etc... and if u r satisfied ??
Old Nov 23, 2009 | 07:34 AM
gsrboi80's Avatar
damn I though I was going to see results back to back
Old Nov 23, 2009 | 07:54 AM
stryfetew's Avatar
We was tricked..
Old Nov 23, 2009 | 07:56 AM
RockmanX's Avatar
lol nobody has done it yet otherwise you would see a nice thread on it i know my friend on here will have his installed in two weeks with results mine will not be dont till feb its looking like most people are going to run it at 35+ psi but im sure after christmas we will have plenty of results as most are saving towards presents and black friday lol
Old Nov 23, 2009 | 08:15 AM
crcain's Avatar
Going to bigger turbos, while limited to a low octane fuel is always a tough one. The octane will limit the boost pressure you can run. The bigger turbo allows you to run more and more boost. If you are octane limited, you can't run more boost.
Boost for boost, a bigger turbo only has advantages over a smaller turbo in that it is less restrictive on the exhaust side (larger turbine housing, turbine, etc), and the compressor is more efficient at creating boost. Both of the above are significant but is the black less restrictive on the turbine side than a Red?
A GT40 at 14 psi will make more power than a stock IX turbo at 14 psi. The engine breathes much better cuz the GT40 will probably have a big header and turbine housing. But there won't be a massive difference in power all else being equal.
If you're on 91 octane, and limited to running boost of around 25 psi, the Black is likely to not be significantly more efficient than the Red on the compressor side, and on the exhaust side I doubt the black flows much greater air flow. So I suspect a Red versus Black on 91 octane at 25 psi would be an overall difference of less than 10 hp. Plus the Red will spool sooner
Old Nov 23, 2009 | 08:27 AM
ForcedPerformance's Avatar
I have, does that count? Did them both within a reasonably short period of time on the same car (mine) while keeping as much as possible the same.
They both did right at about 500whp on 93 and 25psi, slight advantage going to the black model in power, slight advantage going to the red on spool. Differences were slight.
Old Nov 23, 2009 | 08:30 AM
fas-n-furyus's Avatar
Originally Posted by stryfetew
We was tricked..
^ +1 ......lol
Old Nov 23, 2009 | 08:34 AM
stockevo03's Avatar
+1^ i was expecting dyno sheets
Old Nov 23, 2009 | 09:19 AM
thanks
Old Nov 23, 2009 | 09:31 AM
RockmanX's Avatar
there you go striaght from the man himself. But he is on built 2.3 i know but still 93oct like you want pretty nasty for 25 psi and be right at 500 sweet. better have double pumper then LOL
Old Nov 23, 2009 | 09:37 AM
EvoRob22's Avatar
That is exactly what I thought when the Black first came out.
Old Nov 23, 2009 | 02:13 PM
LG_4g's Avatar
You have time to spend on the forums but not to answer my email?
Old Nov 23, 2009 | 02:28 PM
RockmanX's Avatar
just call them like everybody else lol.
Old Nov 23, 2009 | 02:40 PM
94AWDcoupe's Avatar
You would have sold more blacks if you would have answered 450 on the red and 550 on the black
Old Nov 23, 2009 | 03:01 PM
BLKCarbonEVO's Avatar
^ Well I agree, but I think the Black will stand for itself here shortly. The Black is/will be a sick *** turbo on the right setups. Having a larger compressor wheel will def help out. Most of us are able to push the Red to the limits of the compressor wheel. The Black is designed to flow at a higher rate and operate more efficient. Robert did a great job at that!
Bottom line for Black on pump...
MAKE EVERYTHING FLOW BETTER AND IT WILL OUT PERFORM THE RED! Certain modifications will make the compressor wheel come to life
Mikey
